brake line rubber hoses 66 4wd
Trying to make some decisions on new brake lines for my 66. I haven't been able to locate the front 3 rubber lines (manifold on axle to left and right wheel cylinders and up to master cylinder). Does anyone reproduce or do I need to go custom? The rear rubber line going from main run of hardline to the rear axle needs replacement as well. The manifold on that line has the rear axle hardlines to each wheel cylinder and the axle vent line attached to it. Is this correct? where can I find that rubber line with manifold? Thanks for any info.
1966 F100 4WD
OBSOLETE RELIABLE PARTS in Nashville GA has 1 = 229-686-5101.
C6TZ-2A420-A (replaced D1TZ-2A420-A) .. Right Front Brake Hose - 47 1/4" long / Obsolete
1966/71 F100 4WD
No Ford dealer or obsolete parts vendor has any.
C6TZ-2A420-B (replaced D1TZ-2A420-B) .. Left Front Brake Hose - 22" long / Obsolete
1966/71 F100 4WD
CARTWRIGHT FORD in Booneville MS has 1 = 662-728-5381.
C6TZ-2282-E .. Rear Brake Hose - 20 5/16" long / Obsolete
1966/72 F100 4WD
Type this part number into ebay, there are 8 available, Dorman makes them.
66v8baby
07-05-2019 10:07 AM
reelickj
09-21-2012 01:11 AM
yellow truck
07-06-2009 04:46 PM
