Howdy folks..i am new here..i am having a rough time and could use some help. i have a 73 f100 4x4 with a 352. replacing front brakes 11x2 drums. the new hardware kit doesnt come with the shoe to shoe return spring. i cannot find it anywhere. do i need it? where doni find it? thank you in advance
The kit in the pic should be the one for 11" brakes. The spring you have appears to be from an F250 12" rear brake. How it got onto your truck is ?. Btw, the engine in your truck would be a 360. The last year for the 352 was 1967.
I will measure them again but i believe it was 11x2 brakes. the motor at some point got swapped out. the stamp on the block says its a 352. the spring i am looking for measure 7 3/4 in rom hook to hook
The Ford mpc DOES show a shoe-to-shoe return spring. (2) are included in kit # D9AZ-2A225-A. Green Sales shows 15 in stock. Call them and see if it is what you are looking for. This number does not cross into any aftermarket part. Green Sales Co. 1-800-543-4959
This is the wrong part number, it's for misc. cars with 10" brakes. There is a D9AZ-2A225-Bkit, but...
It's not correct for 1973/75 F100 4WD's with 11" x 2" front brakes, as the primary brake return spring is wrong.
It's only correct for 1973/75 E200's with front drum brakes and the 11" x 2 1/4" rear brakes of 1973/79 E100/150 & F100/150 & Bronco.
--------------------------------------------------------------------------------------------------------------------------------------------------------- B5A-2035-A .. Primary Brake Return Spring - color coded blue / Obsolete ~ Available NOS & from auto parts stores.
Sometimes, on side jobs, I drive an older-than-dirt itself Kenworth dump truck with no front brakes...apparently they were optional in the 70s...? Luckily it doesn't really go too fast either.
