2003 Expedition, No wipers, no hi beams. Turn indicators work fine.
HELP!
2003 Expedition Eddie Bauer 2x4
Weird.... Turn indicators work fine, but i have no hi beams or wipers or wash.
No bad fuses.
I don't hear any relays click when i turn on wipers or beams.
is it time for a new switch?
how would I test for power at the switch to see if it is getting that far?
No bad fuses.
The common point is the control module there on the steering column. If disconnecting the battery won't reset it you'll probably end up replacing the module (turn signal lever switch...). Does the "Flash to Pass" feature work ? (The momentary high beam flash...)
Does the emergency flashers work ?
-Mike
Expedition Turn Signal Switch from Rock Auto....
-Mike
No, the turn signal lever should not push in at all. I think you found your problem.
Those switches on Ebay may work fine. They're cheap enough you could buy three of them for the price of a Motorcraft switch. Give it a try. Some of them have the same 24 month warranty as Motorcraft anyway.
-Mike
-Mike
Hey Mike,
Sounds good! I am actually going to see if I can find one at pick a part here locally. Will only be $16.00! I think they are the same from 2003 to 2006. Anyway, it's worth a try. I'll check it over good if I can find one there. Otherwise I'll order a cheapo from Amazon or Ebay.
Will keep you informed. Maybe post pictures of the repair. If I can figure that out! Lol! Thanks for the encouragement!
Mike (also)
Mike (also)
Was it a Motorcraft multifunction switch you installed ? You checked fuses 1 , 38 , 113 and they were all good ? Maybe some of those Ebay multifunction switches aren't truly compatible, I don't know, I always use Motorcraft parts. Do you have a multi-meter ? Might be time to start probing.
