Bronco II Ford Bronco II
[PICTURES] Clutch, transmission, linkage, drive shaft, axel problem? Or?
Old 12-07-2016, 03:27 PM
bronco2isaiah's Avatar
bronco2isaiah
bronco2isaiah is offline
Hello! I recently let a dumb friend of mine borrow my 1989 Bronco II 2.9 manual. He was pulling donuts and popping the clutch hard and my gears stopped catching. Clutch still feels springy but all my gears feel like neutral. The gears are not catching and so on of my gears will send my car forward.
Ive tried putting it into 4x4 low and high and nothing has changed. I don't know what the problem is!
however, if you look at the picture, something is very wrong with the drive shaft.
Thanks so much! I'm going to need this baby for the winter. Looks like a screwed up drive shaft.
Old 12-08-2016, 03:30 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
OMG, your frined didn't do you any favors....it might be as simple as a new pinion seal/assembly & u-joints or could be much more extensive.......
Old 12-10-2016, 09:32 PM
HappyJack's Avatar
HappyJack
HappyJack is offline
Looks like the driveshaft is broken at the CV. Have someone put it in gear while you look to see if that is the case. Your option are a new one at your local parts store or used from and auto salvage. Be sure to measure overall length and the spacing on the flange mounting holes so you get the correct part.
Old 12-14-2016, 11:21 AM
Isaiah Wier-March's Avatar
Isaiah Wier-March
Isaiah Wier-March is offline
I towed my car back home, a horrible grinding and clanking noise would erupt from seemingly the front end of the car.
What kind of clutch or transmission problem could this be? I towed in neutral. My hubs were not locked and I was in Two Wheel drive.
Also, the drive shaft spins even in neutral.
I'm at a loss, what do you all think?
THANK YOU SO MUCH!
moocowman
07-18-2017 02:50 AM
Isaiah Wier-March
Bronco II
01-04-2017 10:02 PM
anthony f47
11-06-2016 08:54 AM
greasolution
04-21-2011 05:24 PM
Vince_psx
1983 - 2012 Ranger & B-Series
08-16-2004 11:23 PM
Quick Reply: [PICTURES] Clutch, transmission, linkage, drive shaft, axel problem? Or?
