Tire Size? 275/65R20 on 2WD
I'm thinking about buying a set of F350 rims and tires that were taken off at 200 miles. Size is 275/65R20. Google tells me these are 34.1" in diameter and 10.83" wide. My 2WD 2003 EB ed. Ex is stock suspension at this point. Any thoughts on if this tire/wheel set up would cause me any problems. Thanks in Advance.
The spacers Mark mentioned will be needed to properly position the late model wheels/tires under your EX. What I'm not too sure about is if 34"s will fit under a stock RWD EX, they may be a bit too tall for the amount of space you have to work with. Hopefully one of our RWD guys will see this and be able to help out.
I have the same size tires on mine.... you'll need to go here and get....
WheelAdapter.com is your number one source for wheel adapters, wheel spacers, used wheels, and wheel studs.
Dave, your EX is a 4X4, do you think that those 34" tires would fit OK on a RWD EX with their slightly lower ride height?
Myfreeford
08-05-2014 04:07 AM
flsurfprep
05-09-2011 06:07 PM
bswill32068
01-25-2009 10:39 PM
gr8199
02-08-2002 01:15 PM
