1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
OBD II /Torque App-tie size speedo adjust ???
Old 12-07-2016, 07:59 AM
RSCHAP1's Avatar
RSCHAP1
RSCHAP1 is offline
Just got new tires on both my own and wife's Expeditions.
2006 and 2004's respectively.
New tires even though labeled same size, must actually be shorter than previous ones.
Speedo is off a little now.
Actual speed on GPS is slower than what speedo reads.
I have an ELM-327 scanner in the OBD port and the Torque app on my phone.
Wondering if these have access and can allow altering the computer to fix speedo and compensate for new tire size...??
Appreciate any help
THANKS
Old 12-07-2016, 08:26 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Short answer is "No" for Torque.
Forscan on a laptop might be able to, provided that parameter is programmable. That's something I've never explored, hopefully someone else will chime in with relevant experience.
Old 12-07-2016, 08:28 AM
RSCHAP1's Avatar
RSCHAP1
RSCHAP1 is offline
Not surprised.
Kind of expected that.
THANKS
Old 12-07-2016, 05:14 PM
lincolnshibuya's Avatar
lincolnshibuya
lincolnshibuya is offline
ForScan can do that using the extended license (it's free) just buy the $31 adapter from amazon and download the app. You will be surprised on what it can do.
Unfortunately I have a 2003 which uses UBP on some modules (which ForScan doesn't support), starting at 2004 they moved away from that.
https://www.facebook.com/diyLincolnNavigator/
Old 12-08-2016, 04:28 AM
RSCHAP1's Avatar
RSCHAP1
RSCHAP1 is offline
That sounds pretty handy and CHEAP enough
THANKS
Old 08-08-2020, 06:02 PM
Lasvegasharley's Avatar
Lasvegasharley
Lasvegasharley is offline
Necro, thread! Did anyone solve this? I have a 2005 Expedition. I want to calibrate the speedometer after installing lift and bigger tires. I have and use Forscan but I do not see any way to change the tire sizes. All of the Forscan threads and spread sheets that I found are for newer Fords. Thanks!
Old 08-09-2020, 07:09 AM
RSCHAP1's Avatar
RSCHAP1
RSCHAP1 is offline
I never did end up doing anything with either of my Expeditions as far as re-calibrating speedo.
Everything I saw back then, and still now says ForScan program/app is way to go.
Congrats on the lift, wheels, and tires, looks good.
Good luck getting everything set up.
Old 08-09-2020, 10:47 AM
Lasvegasharley
Thanks for the reply. The only thing that I have found on google regarding forscan tire size calibration is the ABS Module setting 760-02-01 xxxx **** xxxx . However my setting here is 3534 and I am not sure at all what to change it to.
Rumble phish
2004 - 2008 F150
06-05-2019 04:12 PM
Superduty.pride
32
10-14-2011 07:11 PM
ReAX
Computer Chips & Tuners
03-01-2008 11:58 PM
pfogle
General Automotive Discussion
16
12-28-2005 03:00 PM
cprescott
08-09-2005 08:00 PM
Quick Reply: OBD II /Torque App-tie size speedo adjust ???
