Why You Don't Tow More Than You Should
Received 6,656 Likes
on
Since my trailer is a toy hauler I thought this belonged in this forum.
Trailer weight: 8,200 lbs
Tongue weight: 1,350 lbs - not including WDH
Tow vehicle trailer capacity: 9,200 lbs
Tow vehicle tongue capacity: 920 lbs
Pretty sure the picture below the result of pulling my trailer from storage to my house and back a couple of times. Round trip is about 40 miles.
It's in the shop to get the leaf spring bracket welded. I have reinforcement brackets on the way and those will go on soon. No more pulling the toy hauler with my half ton. My Superduty can't get here quick enough.
I highly doubt being 400 pounds over rated tongue weight "a couple of times" broke your shackle. The crack looks rusted; it's been like that for some time.
I couldn't find data on a 2007 Titan, but the 2005 had a rear axle rating of 3800 lbs. Meaning, obviously, the rear axle was rated for 3800 lbs of weight. You put 1350 lbs on the axle via the trailer tongue (okay, a little more if you want to get super technical because the load wasn't placed directly over the axle) but still, it never came close to 3800 lbs.
Exceeding the tongue weight will damage your hitch/receiver LONG before it damages any axle components.
on
I've been driving on it for a good 600 miles. I've been trying to figure out what my clunk was. I thought it was the shocks so I aired them up but that didn't help. The clunk is fairly recent, within the past 6 weeks which is right about when I pulled my trailer into town to winterize it.
on
on
I hear what you guys are saying. The appearance of the bracket failure and when I last towed the trailer seem to be very close. So I thought the trailer might have been the culprit.
Anyhow, the bracket has been welded back up and I have a set of aftermarket reinforcing brackets that will be installed soon.
That was most likely a stress crack from the forming process, rare but it does happen, it just took a while to show up. I have seen those on brand new trucks when I twisted wrenches at a dealership, happened on 3 new GMC's that had been special ordered and had sequential serial numbers.
on
