Gauge Choices for Info Cluster
Anyone have a list of available gauges that can be displayed on the LCD info dash cluster? The trucks I've driven at the lot have the same 4 from the factory and I didn't dig deep into which things I could look at. Example, I'd rather look at EGT than boost. Its pretty obvious when boost is working, but nice to view EGT or tranny temps instead.
Is this possible? Is there a known list of gauges I can view?
Oh i was under the impression that you could reprogram the top four gauges to show something else. silly me.
Correct only rightmost top gauge is changeable. I swap the boost out for tran temp when towing. Three of the choices are boost tran temp and def level, can't remember the 4th option if there is one.
The 8" display is pretty, but the 4.2" (mid-range display) has very sharp graphics and includes virtually all functions of the 8" display.
The base display is a 2.3" monochrome LCD, and it is a big improvement over the base 2-line dot-matrix display on the 2016 trucks. I think it actually looks pretty nice.
I'm disappointed at only being able to swap the turbo gauge for DEF or trans temp. There are so many things you could do here...
You need to get the XLT Premium Package and Driver Assistance Package to include auto high beams and rain sense wipers. I don't think you can get either package on the R/C truck, unfortunately.
Correct, I believe you can only get the color 4.2" display on the regular cab. That is still a nice display, even the most basic 2.3" display is surprisingly decent.
I hear you, but all you can do is switch the turbo gauge to DEF or tranny temp. That info is available as a readout in the menus anyway. I never move my gauge off turbo; the switchable gauges is more of a novelty I think. I'd like to ditch the oil pressure gauge and switch that with DEF, or EGT, or DPF % full would be great. But they won't let you do that.
