5.0 aluminum radiator which hoses
I recently purchased an aluminum radiator with the port's swapped for the 5.0 swap. So I went to the local part's house and purchased hoses for a 5.0 mustang cause that seems to be what all the bronco sites sell. They don't fit because they are for the mustang and the mustang must have a wider radiator, basically they would work if I cut 3 inches out of the middle and shortened them up. Has anyone else who has the aftermarket aluminum 5.0 radiator in their early bronco had similar issues?
outlet/inlet sides
I'm thinkin ur 'new' radiator has swapped sides (C 'subj. line' above) 4 top hose - frm the orig 1? U may have it 'reversed' frm OEM?
U hafta order the correct radiator 4 ur motor. Otherwise gotta use what's in ur possession now (thru this method we seem 2B discussin)...
Yes I ordered it "swapped" purposely such as the one in this link.
https://www.tomsbroncoparts.com/product/aluminum-radiator-reverse-outlets-for-new-motors-66-77-early-ford-bronco
Otherwise if you run the stock radiator you have to use a crossover tube for the lower radiator hose, such as the part in this link.
http://www.wildhorses4x4.com/product/Cross_Over_Tube_5L
I have a newer efi engine and I am trying to avoid having to cut and splice the hoses to scab them together and make it work.
Dalamatition
06-04-2004 10:27 PM
Scott's 88 F150
03-02-2004 09:37 PM
GreatNorthWoods
02-17-2004 04:12 PM
