6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 Repair Questions
Old 12-06-2016, 03:06 PM
Sarge261's Avatar
Sarge261
Sarge261 is offline
Hello Folks,
I'm normally a 6.0 guy, but I took on a company with a few 6.4's too and they've asked that I work on them and I said yes.
So I have a 10 here that has a plugged DPF, so I'm gonna replace that, it also needs a thermostat and #2 glow plug.
Are there any tricks or surprises to doing the T-stat? DO you guys normally do the GP harnesses as well when replacing the glow plugs, that's a common failure on the 6.0 and the harnesses normally come out in 2 pieces so we just replace them when doing the GP.
Honestly this will be the first 6.4 I've personally had my hands on and I'm a little nervous about it as its "new" to me.
As far as going with a new DPF, he needs to keep the emission's intact as he's subject to DOT inspections.
Thanks In Advance,
Sarge
Old 12-07-2016, 10:44 AM
Sarge261's Avatar
Sarge261
Sarge261 is offline
No One has any pointers? Or is it that straight foreword?
Sarge
Old 12-07-2016, 03:11 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
odds are that the cat converter will be plugged up also
then there is the root cause issue as to why the exhaust system got plugged up....is there oil burning from a turbo seal, work rings, combustion problem due to worn rocker tips, etc.
the DPF cleans pretty easy with about 3 gallons of berry's carb cleaner. it comes in a gallon can and 3 gallons is about 4 cans that will cost you about 100 bucks on amazon. I put mine in a tall plastic kitchen trash can that was about 14" in diameter, poure the berrys over it and let it soak for an hour. lift the DPF out and put it in another plastic can and rinsed it out with fuel. The Berry's will look like tar after this.
the EBP sensor probally needs to be removed and the EBP hole in the manifold cleaned out with a hanger. theres a you tube video on how to do that.
Old 12-07-2016, 03:18 PM
Sarge261's Avatar
Sarge261
Sarge261 is offline
I would assume that the root cause is the thermostat sticking and the truck not coming up to temperature, also the truck has close to 160k on it, here are the list of codes pulled from it:
P0672- #2 Glow Plug Cricuit
P0128- Thermostat
P240F- DPF Restricted
P2452- DPF Pressure Sensor A
P246C- DPF Forced Limit Power
P2463- DPF Soot Accumulation
P0488- EGR Throttle/Performance
Sarge
Old 12-07-2016, 11:12 PM
163junk's Avatar
163junk
163junk is offline
When doing the thermostats, check inside the front cover where they seal. Cavitation is a problem with the front covers on them. Just went through that on an 08.
Old 12-28-2016, 09:05 AM
Sarge261's Avatar
Sarge261
Sarge261 is offline
Forgot to update the thread,
All repairs were completed no issues, didn't need a cat converter it was fine. Thermostat seals were both torn apart and casing them to stick, replaced all the glow plugs on the drivers side harness was good.
Sarge
Browndj19
12-26-2016 07:02 AM
Lou Mandeville
12-19-2016 03:33 PM
Adam Jacobson
11-10-2016 10:01 PM
JoshB20
07-09-2015 10:01 PM
bigwill44
11-02-2004 06:28 PM
Quick Reply: 6.4 Repair Questions
