Retard - advance cam timing
I have a 71 460 with DOVE heads. The unknown aftermarket cam is a 262/272 degree, .484/.510 lift, with 106/118 degree lobe centers. Using a multi index lower crank sprocket, it was advanced 4 degrees. The motor runs good but demands 92 octane or it rattles terrible. It has about 200 lbs cranking pressure. Is the cam advanced too much? Ideas/suggestions?
Joe R
SW Washington
75 F150 4x4 460
13 F150 4x4 Coyote
Joe R
SW Washington
75 F150 4x4 460
13 F150 4x4 Coyote
Joe R
SW Washington
75 F150 4x4 460
13 F150 4x4 Coyote
Joe R
SW Washington
75 F150 4x4 460
13 F150 4x4 Coyote
It cranks fine, I just thought advancing the cam was overkill and get me some mpg or get it to run on lower octane. Having owned 78 3/4 ton 4x4 with the 400 and a 70 F250 Camper Special 2wd 390 I should have known better.... 10 mpg empty or loaded, uphill or down!
My 2013 F150 Coyote motor gets 17.5 around town and over 20 hwy.
I did not know reduction starters were available... Good info! I just put in a D31M Optima blue top in it.. The thing sat for 5 years in a field. Much under hood rust and interior mildew....
Thanks - Joe
Thanks - Joe
Thanks - Joe
Thanks - Joe
That's right and 4 degrees of advance is as far as I've ever advanced a cam. I did in a truck engine I built for towing, otherwise for general use I wouldn't advance it.
on
I just found this forum. I have a 460 in my 86. I sometimes have a hot start problem. Do you think a reduction starter may solve this? Also, my 460 is completely stock except for an edelbrock carb. How much would getting a straight up timing set help?
I do not think the '86 had a retarded timing set, so changing it won't get you anything, if I am right.
on
86 DID have a retarded timing set. Please start own thread. Your 1971 460 probably is a d1ve block, making it a 10.320 Deck height I believe. If a dove block, should be 10.300 making it more CR. 10.320 might be about 10:1. My 10:1 460s always ran fine on 85 octane with 10* timing and a 180 t stat. Yours might have too much timing. or other problems, or maybe your blockwas cut or maybe your block was 10.300 deck. Hard telling. Either way, sounds like a little too much compression.
Hoping to get more input about this cam timing thing, is an 87 straight up or 8 degrees retarded???????????
This has nothing to do with building a fresh new motor , its what Ford did at the factory in those years to juggle smog control figures
