Brake Connector needs replacing, what is it though?
Afternoon everyone,
After replacing my wheel cylinder on my 78 F250 i noticed that the line connection was farther away than what was on it originally. So my lines in the back were all a few inches short. Thats no issue. Im replacing them since they are old and its just good practice to do it if they are maybe 20 years old. However there is a part that i need some help identifying and buying. Its some sort of junction 3 way connector.
My rear line comes from the proportioning valve to a bracket on the frame. Then theres a rubber connecter from that to the junction. I need some help on knowing how to replace that rubber connector which im sure is cracked and will break if i move it alot, and I need help on what the junction is. Any ideas?
The brass block is part of the flexible brake hose. The piece that goes through the block and attaches the block to the axle housing is the axle vent. All that uses is regular 3/8" neoprene hose, the other end clips to the frame. Just be sure the tiny hole in the axle vent is clear, they plug up easily and can cause unexplained rear axle seal leaks.
Here is an alternate idea. Bulletproof Brake Hose - Rear - 1978-1979 Ford F-150 with 4-9" Lift - 91290 | Superlift
Skyjacker - Stainless Steel Brake Line Rear | 4WheelParts.com
Brake Line Set-Broncograveyard.com
1948-1979 V8 Ford Truck Brake Lines And Brake Hoses Brake Hoses And Lines - Macs Auto Parts
D8TZ-2282-C .. Axle Tube to Brake Line Hose / Obsolete
1978/79 F250 4WD / 1979 F350 4WD
GREEN SALES CO. in Cincinnati OH has 18 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 41 = 800-476-9653.
OldWoodsDiesel
07-17-2013 09:28 PM
Tomahawk2506
06-16-2012 03:51 PM
