390 swap into 73 4x4
Hey all.
So I have a 73 4x4 halfton. Currently has a blown 300 motor with a 4 spd manual.
Friend found me a 2wd 1 ton truck with a great 390 and a 4 spd manual
Does anyone know if there is a way to make the 300 transmission fit into the bellhousing from the 390? I also have a FE 4x4 trans but not sure what kind of shape it's in.
Thanks in advance
Thanks in advance
It might bolt right up. Both transmissions should have the Ford "butterfly" rectangularish pattern. Input length, pilot size and input spline need to be verified as well.
The FE bell housing pattern is different than the six, but the transmissions that do not have integral bells all have the same pattern since 1965.
And yes as long as I can make one good transmission that'll work for me is all I need. Only kicker is I know tran in the 390 is a great working one. One on my 4x4 I think is ok but not sure.
How high of a lift would I need?
I guess I do have a 360 in my parts 4x4 chasis too tho
cowboy.2010
04-10-2010 03:22 PM
Michael Sizemore
15
06-16-2005 02:22 AM
66MercMan
07-10-2003 05:00 PM
