1997 F350 Dually 4x4 5-Speed Build
Does anyone know if I need drop pitman arm? I went threw 2 sets of new steering kits. When I turn it kinda slides and if I drive straight I have play. When I crawl underneath and lift the tires off the ground, I can turn and pay with the steering arms with thus turn the tires about 1/2". What can be wrong?
Yes new tie rods. Ball joints are new maybe 1000 miles on them. Same as gear box. I can crab the tie rods and twist them then when twisting them, they turn the tires and gearbox/pitman arm stays in place. This was don when tires were off the ground.
Reverse shackle kit
Plan:
Take apart leaf springs that were bought at a scrap yard
Paint leaf spring parts
Paint D60 axle
Paint reverse shackle kit
Reassemble leaf springs
Box in front end
Install reverse shackle kit
Attach leaf springs
Attach axle
Install transmission and transferase
Attach driveshafts
TEST DRIVE!
Progress:
Ordered all parts needed online
Reverse shackle kit
ZF5 rear extension housing
ZF5 seal kit
Went to scrap yard and bought leaf springs
Donor trucks looked like "W"'s but has good bushings
Took apart leaf springs
Painted (primer) leaf springs
Work on removing good bushings from old leafs while paint (primer) dries
Cut seam welds and removed rivets (holding boxed end and radiator mount) holding in boxed parts
Second coat of primer
Removed bumper seam weld from dually
Removed rivets holding radiator mount
Had a buddy seam weld box front end
First coat of black paint
Painted pitman arm and new reverse shackles
Had a buddy trade me my old POS steps for his steps. They go from front tire to back tire. They are also quick release sort of steps if ground clearance is needed.
Black Friday weekend/week:
I ordered
PHP Hydra Chip
MaxTow Gauges
Air Filter
3" Downpipe
Pictures to come[/QUOTE]
Hey i know this thread is quite a few years old but this is a project i am getting ready to start. how did you figure out spacing to mount the shackles and leaf spring hangers?
Plan:
Paint D60 axle
Box in front end
Attach leaf springs
Attach axle
Attach driveshafts
TEST DRIVE!
Progress:
Reverse shackle kit
ZF5 seal kit
I ordered
PHP Hydra Chip
MaxTow Gauges
Air Filter
3" Downpipe
Theodawg
16
09-18-2018 03:29 PM
df85732
02-27-2017 07:38 AM
