Well if you're towing that heavy and air bags won't keep you level then I guess you need to do something alse. Are you way over your allowed gross combined?
Which air bags do you have and at what pressure do you run them when loaded?
What kind of rear axle weights are we talking about here that air bags aren't enought help to handle the load?
i have air rite. i run 50 psi loaded unloaded 10psi. my trailer is 12k dry. I guess I'm just trying to figure out if helper springs would be a good investment
You can run air bags up to 100 psi, I personally wouldn't go over 80 but you may have to..... try it and see. The helper springs, given you get Helwig or another premium spring will make your truck ride like chit when unloaded but if that's all you can do to level it out then i guess that's all you have left. I would def. try 80/90 psi first though.
In my 99 I had air bags and loved them. Towing 30' TH loaded and a RZRs in the bed, I ran about 80 psi and all felt stable and good. Are your air bags individually controlled or tied together? If they are not covering it I would say you need a different tow vehicle,
Edit: this is with 5" ride rites, air rites iirc are a smaller diameter bag. May start there
