My Build Thread - 2015 F350 Lariat
Figured I'd start my own build thread so that I can keep track of all the mods I do on this truck for myself as well as anyone that likes to follow or view these types of threads. I wish I had done this with all the mods I did on my 2006 F250 but I failed to really keep a running thread on another forum. Just posted on 'pic threads' and 'what did you do to your truck threads' as I went.
Here was the 2006 when I first got her
And this is what she morphed into right before I traded it in (note, ended up ptm rear bumper, replaced running boards with black ones and ptm front bumper but didn't get a picture of that beforehand )
That don't even show all the mods done under the hood and truck...
So anyhow, here is the 'new to me' used truck when I purchased it...29,500 miles
It's a 2015 F350 CCSB. Lariat Ultimate Package, FX4 Package (decal removed), Snow Plow Prep, 5th Wheel Prep, Spray In Bed Liner, Tonneau Cover, 20x8 OEM Wheels, Moon Roof
First mod was to add weather tech liners to the truck...no pic.
Second mod was to add kick protectors to the back of the front seats. I have 2 boys, and they love to put their muddy boots on the back of the seats for some reason...
Got them off Amazon...cheap...
The next mod I made was replaced the factory fuel cap with a lockable cap. Stant 10510D cap.
More to come...
More to come...
Today:
Installed a 3.5" Readylift SST kit.
Before:
Front End
Tire Pressure - 80psi
41-3/8" ground to fender edge
Rear End
Tire Pressure - 62psi
43-3/8" ground to fender edge
After:
Front End
44-7/8" ground to fender edge
Rear End
44-5/8" ground to fender edge
Replaced the rear 4" blocks with 5" block that came with kit.
3.5" spacer lifted the front.
Kept the stock Rancho shocks for now.
Sway Bar drop brackets
Track Bar Re-position Bracket and Bump Stop drop bracket
Radius arm drop bracket.
Not happy with not being able to put the plastic ABS clip into the radius arm. Would think they would supply in the kit an extension clip or something. Will have to fab up something myself I suppose.
Install time...5 hours
2 - guys
2 - 3 ton jacks
4 - 6 ton jack stands
hand tools and air tools
Had to adjust the steering wheel a bit after installation but seems to be tracking just fine.
I purchased a Rancho Steering Stabilizer kit but did not install that today. That may go on tomorrow.
Will be shoeing it up with 35x12.5R20 Firestone Destination MTs this coming week. Will update when done.
More mods to come...
Before:
Front End
Rear End
After:
Front End
Rear End
2 - guys
2 - 3 ton jacks
It's a 1/4" higher in front. I don't like bull ******* it. Not sure if that has to do with the fact I have snow prep coils on the front or not. I plan on running air bags in the rear in the future, so that should level it up or put a slight rake back into it as well as help when loaded with my 36' camper. I don't want to go any higher with just blocks, so add-a-packs or new rear leafs would be my only other option to correct unless there is something else out there. I think the bags will work just fine once I get them.
What is the brand that you put on it?
