Pennzoil Ultra Platinum 5w-30 UOA Ecoboost F150
Old 12-02-2016, 04:24 PM
mdowell12's Avatar
mdowell12
mdowell12 is offline
Figured I would share if anyone was interested. The new Pure Plus Ultra Platinum seems like a damn good oil for our Ecobeasts! I have always used a Motorcraft oil filter and switched to a Motorcraft air filter for this run. I think I will stick with the Motorcraft filters going forward. I also run an RX Performace dual valve catch can which catches A LOT of gunk in the winter time.
Old 12-07-2016, 07:02 AM
WXboy's Avatar
WXboy
WXboy is online now
With all due respect, that's only 3,450 miles. You could buy the $1.78 chinese stuff off the shelf at K-mart and have a great analysis at 3,450 miles. To me, this report means absolutely nothing.
Extend your interval out to 7,500+ miles so that the additive package is getting a little useage and then lets see what the analysis shows.
Old 12-07-2016, 07:08 AM
mdowell12's Avatar
mdowell12
That is the plan! With this UOA I feel a lot more comfortable with a run like 6 or 7k going forward. But the point was that at 3,450 miles, it protected better than Mobil 1 at 1,833 miles. The only reason I ran such a short interval back then was to test for fuel dilution. Which apparently is not a problem with my dual catch can setup. But I understand your point!
Old 12-07-2016, 01:14 PM
fordiesel69's Avatar
fordiesel69
fordiesel69 is offline
SOPUS oil products and fords go together for some reason. My 4.6L engines have always had steller results. I was a huge mobil fan for years but had more bad UOA;s than I should have. That one looks really good. Why not try pennzoil yellow bottle for 5k miles and not worry about extended drains?
Old 12-07-2016, 01:18 PM
mdowell12's Avatar
mdowell12
Glad I am not the only one disappointed with Mobil these days. For some reason I get nervous using a conventional in an engine with twin turbos, otherwise I would have no problem doing that. Also, since it's 4 degrees outside right now and snowing, a synthetic sure helps with the cold starts too. Those modulars were legendary for reliability if taken care of too!
Old 01-07-2017, 06:23 AM
ExcursionPSD's Avatar
ExcursionPSD
ExcursionPSD is offline
Idling when cold, and other operational behavior, is often the cause of fuel dilution in a gas engine. Has your vehicle every had a fuel dilution problem?
I don't think the dual catch can setup would affect fuel dilution.
Old 01-07-2017, 11:17 PM
mdowell12's Avatar
mdowell12
Actually you are incorrect, the dual catch can setup is a huge part of helping to remove the fuel vapors from the oil. Also the moisture too. I caught this after only 360 miles of driving in cold temps.
This is over a span of 6 days and probably 14 cold/hot cycles. Without this the vapors and moisture are not caught and it just keeps hitting the back of the intake valves and going back into the engine/oil through the PCV system. In my opinion, this is a necessity in the 3.5 Ecoboost if you want to get 300k miles out of this engine like I want to. Absolutely amazing engine, just need a dual catch can setup. The efficient catch can (RX Performance in my case) on the dirty side, and a cheap one will do on the clean side. My clean side catch can needs to be emptied every time I take a long trip with long periods of boost because the normal flow of the PCV system is reversed during boost.
tiffy2000
Modular V10 (6.8l)
07-11-2019 06:49 AM
tyson_hasselhoff
1983 - 2012 Ranger & B-Series
11-12-2013 04:10 PM
Supercab
04-26-2009 07:15 PM
cocot
Oil & Lubrication
19
01-28-2004 10:33 AM
BIlltheCat
Oil & Lubrication
24
08-07-2003 12:06 PM
Quick Reply: Pennzoil Ultra Platinum 5w-30 UOA Ecoboost F150
