Need help Hot Stalling f250
Hey everyone. I'm hoping you can give me some advice on an issue I've been having.
My 1994 f250 5.8L auto has been randomly shutting off while idling at a red light and turning corners (also reversing) only seems to happen after a bit of highway driving to and from work
The engine itself dies while all accessories stay on. Seems to be avoidable by keeping the rpms up but still stutters a bit.
Tried replacing the idle control valve which fixed it for a day. Cleaned the intake. Seafoamed the entire truck. No codes tripped. Recently replaced map sensor. Plugged egr.
Turns back over every time with ease. Battery tested same with alternator. What else should I be looking at?
Thanks.
Thanks.
checked any codes available. No codes stored. Check engine light isn't on at all. Seems to happen when there's a lot of load on the battery but alternator reads fine
Superduty.pride
12-03-2013 10:34 AM
jhnhardee
12-24-2005 06:13 AM
illustriousday1
12-22-2004 06:37 AM
