Additives
Ford sells PM-22 and PM-23 Check page 58 of your diesel supplemental owner's manual. I believe PM-22 is more of a cetane booster than a demulsifier product. PM-23 is a product for gel prevention in addition to cetane boost. I use the Stanadyne Blue (year round) and Red (summer) for cetane boost and demulsifier to help remove any water.
PM-22
https://www.fcsdchemicalsandlubrican...nce%20Products
PM-23
PM-22
PM-23
There is a way that certain additives can hurt these motors.
Ford, and other auto makers, all have recommendations for the type of additives to use, if any at all. These are additives that improve cetane, lubricity, and when necessary..... anti-gel. That's it. They do not recommend any additives that do anything else.
The additives that can be harmful are those that go above and beyond what the auto manufacturers recommend. I'm talking about the additives that contain chemicals and products designed to clean injectors and injection systems, and/or designed to emulsify/demulsify water.
Cleaning agents can actually reduce lubricity in certain situations, like in the HPFP. That's because these agents are typically alcohol based. HPFP setups in common rail systems are not very tolerant of these alcohol based solvents.
Agents that emulsify/demulsify water can actually push water past the W/S and into the HPFP, injectors, etc. This prevents the W/S from doing its job properly, and contaminates the high pressure fuel system which over time can lead to eventual failure.
With proper maintenance, there is no need to use alcohol based solutions to clean out the fuel system. There is also never a need to emulsify or demulsify water. Let the W/S do it's job like it's designed, and maintain it properly by draining it periodically.
