Coolant tee / Y connector
5.0 seemed strange because my friends started to leak then cleared up after a while then mine leaked and that was the end of that tee
Apparently it's pretty common, mine drained the reservoir tank(3/4 gallon or so) the other day. I called brandon ford here locally and immediately after I described where the drip was (right beneath the intake) he finished with the black Y piece before I could tell him. Mine is leaking from the side with the larger diameter hose that goes from the Y under the intake to the top of the radiator on the passenger side. I forget the part number but apparently it's on back order. If anyone knows the # please post as it's still intermittently leaking and I need it sooner as opposed to later. I'm also right at 55k. My 2011 5.0 had 68k without a drop leaked.
I searched "f150 5.0 coolant t / y connector" and the first image linked to the following site.
https://www.powerstrokeplus.com/oem-...1oIaAjAt8P8HAQ
Manufacturer: Ford
Part Number: DR3Z-8566-A
Part: Connector Hose
Manufacturer: Ford
