Numberdummy/Jefffafa
Yeah, it's in the ford box too. One thing they don't have is the horn jumper "wire" which is impossible to duplicate authentically because it is riveted together when it's made, except in service parts apparently. I want it to be exactly correct because the steering column shaft is supposed to orient to this coupler with a blind spline, in other words in one spot only thereby keeping the steering wheel correctly clocked.
YEPPER.
1969/72 F100/250 (4X2) and F350 was part number C9TZ3A525B. This was "replaced by" your D3TZ3A525A. Then D3TZ3A525A was "mixed with" C9UZ3A525A. Back in those days if a part was replaced by another and was the same it was "replaced by". If a part number was replaced by another of a part that was close enough to work but not exactly the same it was "mixed with". So, the info Ford gives me is the D3TZ3A525A coupler should be the same as the original part number,in theory. If you want concours originality the below company shows having the original C9TZ3A525B. When you call them you might ask if it's a NOS Genuine Ford part just to make sure.
Premium Listings
Obsolete Reliable Parts
Part Number:C9TZ-3A525-B Seller:Obsolete Reliable Parts - Description:COUPLING - STEERING GEAR INPUT SHAFT TO STEERING COLUMN SHAFT Phone 1-(229) 686-5101
Price:Request Pricing Email:Send Seller Email Inquiry Quantity:1Location:Nashville, Georgia
Premium Listings
lupindrake
08-28-2014 05:49 PM
