1996 5.8l roller engine questions
#31
I really appreciate all the help and input so far, thanks guys. I got the oil pan off and there is no evidence of cracks in the webbing so we are good to go. My engine has an oil cooler on is that is plumbed into the incoming coolant from the radiator. I'm not sure if I should keep it or pull it off. I'm just seeing it as a possible point of failure and cross contaminating oil and coolant. But if no one has ever heard of that happening and it would be beneficial to keep then I will.
Im on the fence of wether to change the timing chain and water pump while I have the engine apart. I didn't want to go to deep into it but Not sure... thoughts?
Thanks
Thanks
#32
It's got a double row roller timing chain, unless it's really loose, I'd leave it alone. This type lasts a long time. I would change the water pump while it's on the stand, it'll be a lot easier to deal with the longer bolts. These have a tendency to twist off due to corrosion between the bolts and the timing cover. Get a heat gun and heat the timing cover where the bolts pass through it while applying a small amount of torque to the bolts, if done right, you can get the bolts out without twisting them off. Get new bolts if the old ones are badly corroded, apply thread sealer (Teflon pipe thread paste works) and apply antiseize to the bolt shanks to keep them and the timing cover from corroding together.
#33
These heads are ideal and will serve you well..
https://www.summitracing.com/parts/mll-hp9008
Pedestal Mount 1.7 Roller Rockers are $335/set.
https://www.summitracing.com/parts/fms-m-6564-a50
#35
#36
#37
I'd leave the timing set alone. 57K is just broke in. You'll gain nothing with a new set. As for the cooler, take it off and give it a thorough cleaning with spray carb cleaner to the insides. Let it dry, then repeat it. With the cooler on the engine, you can then use a oil filter for a 370 that is longer and holds another 1/2 quart of oil.
#40
How would it do that ? When I install it I fill it with oil before screwing it on, just as I do with any filter. After that it stays full of oil. Oil, like water will not run uphill without a pressure differential to move it.
#42
#43
Neat trick for broken bolts. Use dry ice on the bolts - they will shrink in the block then unscrew. Hopefully you will only need vise grips to unscrew it, if not slot the bolt use a screw driver. No need for heat or drilling.
Also check out the "Grabit" tool to remove bolts - works wonders. https://www.thegrabitstore.com/
Yes I have broken my fair share of bolts, mostly steel bolts into aluminum.
#44
80'BUB
05-31-2017 06:30 PM
TheSilverBullet
03-11-2010 07:43 PM
1966Tbird
08-11-2009 04:39 PM
saleen065
07-23-2008 09:30 AM
OneFine69
02-10-2003 07:09 PM
