Help: Extremely low fuel pressure at WOT - 20 PSI
With respect to my friend Nicmike, that's a little counter-intuitive. I have seen O-ring leaks between the oil and the fuel go completely the other way: The ICP pushes the fuel pressure up... but it's the ICP that sags. I have even seen people here and there call the ICP "fuel pressure" - which is almost correct, but not quite the same thing.
I'm not saying O-ring leaks alone aren't going to cause low fuel pressure - but I'm struggling to wrap my head around a root cause. A bad bottom O-ring would allow the fuel pressure to escape into the cup, but the cup should eventually equalize in pressure - unless there is a bad copper washer to go along with it. A bad copper washer would introduce combustion pressures into the cup - and slide right past the bottom O-ring. We're back to spikes of fuel pressure because the fuel is surrounded by pressures much higher than 60 PSI.
Now... take out the integrity of the cup, and the low pressure of the coolant is very inviting for the incarcerated fuel pressure to escape.
You mentioned swapping the sticks. Did you try the O-rings only before swapping the sticks?
Part of my struggle is I am relaying all of this information to my mechanic, and he is trying to figure out the problem at the same time.
In your case - I strongly suspect fuel pickup issues.
I ran 3/8" hose from the tank sending unit directly to the PS120 and then to pump. At all connections to the pump, PS120 and tank I used fuel injector hose clamps (double on the pump) and gasoila thread sealant on the PS120.
This thread has a bunch of pictures from my install, but the ones you are really interested in are below.
https://www.ford-trucks.com/forums/1...ne-almost.html
Fuel pump inlet
PS120
Sending unit after modification
Since doing this tank/fuel mod the truck idles and drives at speed much quieter. In addition, I increased the OEM tank capacity by 7 gallons from 26 to 32 with no puking each time. As an added bonus, I widened the fuel port hole to accept "big rig" pump nozzles.
Fuel pump inlet
PS120
If you mean the inlet to the pump, I removed the quick connect and then slide the hose on the inlet, then clamped down. As you can see, I used some sort of sealant (yellow in color in the pictures) on the ends of the hose after clamped, but cannot find the name or product now. I don't think this was a necessary step, but figured it could not hurt at the time. The blue colored stuff is loctite as I did not want to bolts backing out from the vibration of the pump or frame.
I see it. It's right there. Smack in the middle of the picture, there is a vacuum leak. The pump has it going on with dual clamping, using fuel injector clamps - then there's that pitiful single worm drive clamp on the filter.
I wouldn't take it to the mechanic until after you've beefed up the clamping situation with your prefilter. Once that's done - evaluate if you need to take it further.
There is no question the oil was getting into the fuel filter...and fast. The drop in pressure usually did not last more than a few seconds in my case, because this isn't a hot rod truck I drive around for amusement. I rarely need to dive into the skinny pedal hauling kids around the countryside. I only noticed the problem because I installed a fuel pressure sensor at the same time as the hutch mod, FRx and fuel bowl mod. I did not replace the o-rings on the injectors, because I knew I was getting new-to-me injectors in the not too distant future at the time.
The problem is completely gone with new injectors/o-rings. Nothing else was done when the problem went away. Prior to that, I checked every single thing that was mentioned in this thread...and then some.
Yes, that is the filter on the outlet side. Does the filter need double clamping? I paid my Mechanic to install the RiffRaff Hutch kit, and looks like he only used some of the fuel injection hose clamps, and a few worm gear clamps. I don't think I have a way to see what the clamping situation looks like on top of the fuel tank unless I were to drop the tank. I am assuming that the top of the fuel tank needs double clamps as well?
I am going to add double clamps where I can get to, and check to make sure the FRx spring is seated correctly.
#28
on
#29
#30
