to additive or not to additive
Hello,
I'm trying to decide if I should use fuel additives or not, in my new F250 6.7. Ford says that additives should not be necessary.
Others want to prevent gelling in the winter and boost cetane ratings.
I live in Indiana, where it can get cold, but usually not below zero.
suggestions would be appreciated.
its hard to say what the value is on the additives...most folks add them as a safety net.
zinc oil additives supposedly help with wear..but contaminate the cat converter
nano oil additives supposedly help with lube..but if they move into the exhaust process as part of oil burning...could clog exhust componets
newly introduced carbonate type of oil additives supposedly fill in micro pores..but also impact exhaust componets
fuel anti gel additives seem harmless on the surface...but I wonder what they do to HPFP seals
at the end of the day, for a vehicle in warranty..I would just stay with OEM recommended stuff and worst case...use the heavy use duty schedule for maint.
its all a crap shoot. I use some of the oil additives and broke a rocker arm anyway. maybe it got me 50 more miles...dont know.
Warmer weather I use the Motorcraft..22 stuff, forget the whole name,for lube and cetane boost. Since cold weather set in I use Cenpeco Atomic anti gel and lube. After I use up my Motorcraft stuff in the spring,I will switch to Cenpeco summer stuff...The Atomic seems to work very well and 2 local shops sell and swear by Cenpeco in their own trucks. One is also a Amsoil distributor....If that says anything???
