Great retrofit
Great retrofit
I recently took apart an untouched '96 300. I learned a few things that will help with the build of older engines.
1. On the spacer plate, that sits between engine and trans, there was a foam ring to secure the rear main, or to give an extra seal. I like that.
2. The tiny efi starter is great for engines where the headers/exhaust trap a conventional starter.
3. The efi engines have added slats or rails for the oil pan. They sit on the mounting surface of the oil pan, one on either side, and distribute the bolt pressure evenly.
4. I was always told to put a bit of sealant around the keeper for the harmonic balancer, on the crank. But I was surprised to see oem sealant on the leading edge of the h.b. that slides through the seal.
1951flatheaddave
01-14-2012 05:01 PM
Bluegrassboy70
11-06-2009 11:06 PM
Bullride_101
09-22-2007 10:39 PM
turbogus
10-30-2001 07:44 AM
