December All Topics - everyone's welcome!
#32
Recently had been having start issues and been digging under the hood. Replaced ICP, GPCM, replaced IPR screen, purchased a WiFi OBD reader and got Forscan for laptop and iPhone, cleaned EGR, and have some o-ring kits with an injector on order to polish some spool valves and troubleshoot one possibly bad injector. She smoking a ton after a hard start right now. Been learning a ton and having a decent time doing it.
Have you run a live diagnostics test to determine the bad injector(s)?
You replaced the ipr screen. Did it show holes or debris to necessitate? The early hpop's are vulnerable to self destructing and sending debris out, some that can damage the ipr.
What's your icp oil pressure as you know you must see 525 lbs to start. Not easy to override on early models with the rear location of the icp.
I take it that you cleaned the egr valve? If so, how did it look? Totally dry and clean?
You might have a standpipe o ring leak but you'd need to start with an air pressure test and a stethoscope if that initial oil pressure is weak.
Quite a project to polish those spool valves, so I take it that stiction is a problem too?
I agree that with all of that smoke, a possible injector is one of the culprits.
Maybe more then just a day get together?
#33
Yama,
I got the Forscan for my phone and put on the laptop too. No other diagnostics other than a buzz test. Had the #5 and #8 not buzz. Checked wiring harness and no chaffing. Moved around the different connectors to different injectors and got #5 to buzz every time now, but #8 would not regardless which connector was on it. So not sure if a harness problem for #5. Have an injector on the way to assist in troubleshooting, if need be then replacement. ICP and pigtail were changed purely because of an oil leak that turned into a no start, which was first problem. Hard cold starts began some time later to now just puking white fuel smelling smoke once started. Synthetic oil changes, motorcraft fuel and oil filters, and couple quarts of Hotshots for the initial possible stiction. Used the Forscan to show good FICM volts, good Vref, ICP pressure is not 100% consistent but does build to 500-1500 most of the time relatively quickly. Batts load tested good and topped off as I have been playing around. EGR was dry and dirty, but not as bad as some videos I watched. Cleaned and seemed to work fine. IPR screen and rings were perfect, but replaced anyway so no obstruction or hang up there. Did the EGR and IPR since simple to do and everyone seemed to point at those just to count out as possibilities. GPCM was replaced because before the smoking I kept throwing a P0673 code, but glow plug and harness showed no opens, shorts and ohm'd within spec. Plus everything I read up showed GPCM. Fuel pulse width showing and never checked fuel pressure, just installed blue spring (still want to get a fitting and gauge just to be sure though).
I think I covered it all so far!!! I am sure I missed something. Been reading for months and doing this and that from videos and posts. Don't like to be a part swapper since that usually doesn't solve the initial cause of the problem.
-Chris
Last edited by Yama4fitty; 12-10-2016 at 04:46 PM. Reason: Fuel pulse and blue spring added.
#34
I've had to replace 3 injectors over the last 3 years, two that wouldn't spray and one that went bad "open", dumping fuel into the cylinder when not running.
When the open one went bad, I had to manually turn over the engine to ensure it didn't hydro lock and damage that cylinder before starting. Even if I let it set for 30 minutes, you could hear the initial "knock" of too much fuel accumulating in that cylinder.
Both times, I took it in for a live contribution test to clearly determine the injector. Cost me about a hundred bucks but well worth not guessing.
Maybe next step?
Maybe next step?
#36
Maybe next step?
Maybe next step?
Was going to start looking into other less expensive options that can do the contribution test. Might be worth spending a bit of money now to perhaps save more later.
Hello back at ya!! Will be enjoying this beautiful weather in the air.
#37
Keep in mind the spool valve fix should help with stiction but not sure it will alleviate a non working injector. That spool valve moves back and forth between a positive and negative winding to open and close the oil pressure applied. Never heard of one incapacitating an injector completely.
https://www.ford-trucks.com/forums/1...l#post16785004
#38
I've only have experience with the IDS system with Ford and a local shop vs the AE but here's a current link for a bit more info.
#39
This new truck is great! The Ecoboost is amazing. Got this Mpg mix of city and hwy. It's got a mild tune, otherwise stock.
This is a satirical post emphasising in the massive amount of Mpg talk in the Ecoboost world.
#40
I've been down that road a few times Trey. I recall downshifting to 2 to keep from going over the limit. Hope it was a great weekend!
hopefully you didn't have to fill up fuel at Furnace Creek, Stovepipe Wells or Panamint Valley.
