1954 F-250 223 Alternator Bracket Search
Greetings All,
I am restoring a 1954 F-250 Long Bed with the 223 Cubic inch 6-cylinder engine.
I would like to convert to a 12 volt system. Most 12 volt parts seem to be readily available including alternators.
However I have not been able to find a mounting bracket for the alternator.
I am seeking suggestions as to where I can find a bracket to mount the alternator.
Alternator brackets for the Y-block V8 engine are available but I have not been able to find a source for a bracket for the 223 cubic inch 6-cylinder engine.
If they are just not available please post photos of a homemade bracket(s), or other suggestions.
Thanks for your time,
Bob
Bob
There is a specific kit for the flathead six's, but universal alternator mounting kits are in abundance. Here is a sampling.
https://www.amazon.com/s/?ie=UTF8&ke...l_30spqovjd6_b
Thanks for your response.
Can you help lead me to a "specific kit for the flathead six's" please?
I Googled for a specific bracket kit and already found the universal brackets you identified. I have no idea which would best lend itself to my situation.
I have no restoration or mechanical experience. I am an Oracle Database Administer and a hobbyist woodworker. I received this truck from a friend who passed away.
Thanks,
Bob
Thanks,
Bob
Welcome to the forum, Bob!
Your engine is not a flathead 6, it's the OHV 223. There are several members on here who have fabbed up a bracket for their 223's. Here's a thread:
https://www.ford-trucks.com/forums/1...l#post14569083
This is the bracket I used on my 254 six. If your adjusting arm anchors on a water pump bolt you should be good to go. Note that you will want to install a small diameter pulley to compensate for the lower RPM engine. They are available in wide and narrow sheaves.
1948-1951 Ford Flathead H Series 12 Volt Alternator with Bracket | Vintage Auto Garage
svolpone
12-09-2014 03:55 PM
John & Old Ford
12-07-2012 10:11 AM
Duramaxfanatic1
01-01-2011 11:15 AM
mollmanhj
10-16-2004 09:50 PM
