50 f3 brake and fuel line
Old 11-30-2016, 05:24 PM
Partke's Avatar
Partke
Partke is offline
Does anyone know if anyone sells brake or fuel lines for a 50 f3? How about brake pads? Should I look for different brake drums? Disc brakes? Just planning things out. Thank you for everything .
Paul
Old 11-30-2016, 05:48 PM
EAK69's Avatar
EAK69
EAK69 is offline
Do you still have the original brake pads? I took mine to a clutch and brake shop in PHX and they redid them and made them look good as new. Cannot remember the cost but it was well worth it....
Old 11-30-2016, 06:08 PM
pineconeford's Avatar
pineconeford
pineconeford is offline
Knuckle Bandage Sales Rep
Paul, contact Jackson's Auto Parts 6220 Grand Ave, in Duluth, MN. (sorry I don't have a phone number on my notes paperwork)
He sells a very reasonably priced brake line kit for the F2/F3.
I haven't installed mine yet, but was very happy with the contents of the kit and it should be all I need to do my truck.
Tom
Old 11-30-2016, 06:14 PM
pineconeford
As for the drums...they are nearly impossible to find. The shoes (these trucks don't have pads) can be easily found once you confirm your diameter and width since the size is shared for many years. The wheel cylinders are a little trickier but still can be found without much trouble. Measure your old ones first and take a close look at the shape...Ford made changes from 1948 to 1952.
Tom
Old 11-30-2016, 06:45 PM
Partke's Avatar
Partke
Partke is offline
Tom
Tom,
Big thanks. I'm on it. Merry Christmas and happy holidays.
Paul
Old 12-01-2016, 12:08 AM
GoldCo's Avatar
GoldCo
GoldCo is offline
FWIW, I've got F3 front drums (and backing plates) which I do not need... truck had 13K miles on the odometer. Complete rear axle, too, but apparently not OEM (Eaton HO72).
Tom
Old 12-03-2016, 02:12 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
I would recommend front disk brake wth a dual chamber master cylinder for safety.
F1 parts will fit.
Old 12-05-2016, 05:29 PM
EAK69's Avatar
EAK69
EAK69 is offline
The shoes (these trucks don't have pads) can be easily found once you confirm your diameter and width since the size is shared for many years.Tom
Yeah, I should have caught that!!!
Old 12-06-2016, 02:51 PM
fking1's Avatar
fking1
fking1 is offline
Inline Tube in Shelby, Michigan makes brake & fuel lines for old vehicles.
Got my 55 brake lines there.
Check them out.
Old 12-06-2016, 02:57 PM
Partke's Avatar
Partke
Partke is offline
Thank you so very much. I will call them. Happy Holidays.
Paul
Old 12-06-2016, 03:48 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
It isn't hard to make your own. NAPA sells both brake and fuel line in 25' rolls, and a quality double flaring tool and bender can be at your door tomorrow from Amazon, Eastwoods, etc. It's also not a bad idea to have extra tubing on hand because it's real easy to have a brain freeze destroying a section of tubing. Ask me how I know! Stu
Old 12-06-2016, 03:55 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
I bought the Eastwood flaring tool and made all my brake and fuel lines from 25' rolls. It was very easy to do although, like Stu said, I did have to make a couple of lines twice.
Mark
Old 12-06-2016, 03:59 PM
truckdog62563
That's the risk when buying the pre-made kits. Screw one up and you're SOL. Stu
Old 12-06-2016, 04:00 PM
fking1's Avatar
fking1
fking1 is offline
Inline uses a computer controlled machine to make the lines in a correct match.
For me much easier to let them do it and not too expensive.
Old 12-06-2016, 04:10 PM
truckdog62563
Maybe it's easier on a 2wd than on a MH to fish the lines through all the frame obstructions, but seems it would still be tricky. I also sleeved mine for abrasion and fire avoidance. Stu
Quick Reply: 50 f3 brake and fuel line
