Upgrade to Electronic locking differential
the computer controls it..
but there is a post "here" that said.. a switch and wire is all that's needed for lock and un-lock.
maybe be able to swap internals... and drill a hole for wire. no sure on this part.
hopefully others knowing more will be along shortly.
my 2012 has the E-Locker.. it is great. even with 2 wheel drive. better then posi-traction.
im looking into this, the rear axle is a dana 60? i have 3.73 gears. im trying to find the correct one. ARB is compressored correct? and this unlike detriot FULLY disengages?
the arb locks with air pressure and fully unlocks with out once the pressure is released. Detroit lockers are okay i had one in my 99 250 with the 7.3 and about every 6 months i was replacing my back tires. it would lock making slow speed turns and when pulling out into traffic and was very unpredictable when the road was wet you could hear it lock and unlock sometimes kicking the back end from side to side in the process.
Eaton elockers or arb would be the way i would go
I have a Detroit locker in my f350 for about four or five years now and I can't say but good about it. I tow and haul and it doesn't eat tires any differently than the stock ls, and unpredictable? it's a locked rear end it won't slid out UNLESS you hammer the skinny pedal and force the truck to slid. I drive all winter in the snow with no weight in the bed and my truck stays planted UNLESS I want to play! I'm not gonna lie ever once in a while you get that legendary Detroit locker clunk but it dosent make the truck jerk or be uncontrollable
