Temp gauge
Temp gauge
Been searching for a 65-66 temperature gauge to make up a standard cab instrument cluster, find the temperature gauges are few and far between. Came across a later version, 67+, appears close to the 65-66, slight variation, but before purchasing thought I would check with members who may be familiar with the later gauges and have compared? Hard to tell from pic if the later gauge face is larger?
Comments appreciated/Suggestions appreciated!
C1TF-10883-C .. Temperature Gauge-Use with round speedometer / Obsolete
1961/66 F100/1100 / 1963/66 N/NT500/1100.
AL WHITE MOTORS in Manchester TN has 1 = 931-728-9700.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
HUDIBURG PARTS DEPOT in Midwest City OK has 1 = 800-800-5963.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
USD INC. in Phoenix AZ has 4 = 602-258-1900.
C7TZ-10883-C .. Direct Reading Temperature Gauge-Round Dial / Dial reads: C 115 160 180 200 230 H / Obsolete
1967/69 F/N/NT800/1000.
I may be able to ID the other temp gauge, if you get the ID number off the back of it.
Thank you Bill, intend calling the sources U listed and inquire as to price. O' Well, story of my life; too many 'opp's I missed another one' and now suffer from the 'early bird catches the worm' syndrome, had I waited for your post may have saved a few $? Made the purchase, will know in a few days if it fits, or as a center piece for the mantel?
The gauge in question, which according to the seller, NEW, is for a Ford 67 thru 72 Ford truck application, it was a direct fit, except for very slight variation on the face, very pleased that I was able to locate a suitable replacement. Intend calling couple of the sources mentioned to compare cost.
Number on the face of the gauge: 57790(8)N
Or
57790(B)N
InfantryCPT
29
04-15-2015 01:19 PM
