Will a Duraspark "blue grommet" from a 302 work on a 351?
Old 11-29-2016, 02:31 PM
reamer's Avatar
reamer
reamer is offline
Hi all
Will a 302 Duraspark module work with a 351? or are they "displacement specific"????
As a separate note, can a 302 Duraspark wiring harness work on a 351 engine?
I can get a used
302 dizzy, wiring harness, and blue grommet module, but I have a 351 4V.
Only interested in the Module and Harness for my 351, and will toss the dizzy.
Thanks
Old 11-29-2016, 02:41 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by reamer
Hi all
Will a 302 Duraspark module work with a 351? or are they "displacement specific?"
The blue module is not engine specific, it was introduced in all 1976 FoMoCo vehicles.
Old 11-29-2016, 03:12 PM
reamer's Avatar
reamer
reamer is offline
Thanks Bill
So I could use the harness and module when I convert from my current HEI one-wire to Duraspark II?
Old 11-29-2016, 07:49 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,654 Likes on 1,337 Posts
Yes, the v8 harnesses will be very close or the same. You could even use the six cylinder module and harness, but the wires may be the wrong length since the engine is radically different in size and configuration.
Old 11-29-2016, 07:53 PM
reamer's Avatar
reamer
reamer is offline
Cool! that's 3/4 of the battle, finding a usable harness, (without paying "Painful Wiring)
Old 12-03-2016, 04:19 PM
reamer's Avatar
reamer
reamer is offline
If I find a Blue grommet module from a Six cylinder, will it work on an eight cylinder engine?
Old 12-03-2016, 04:22 PM
NumberDummy
The blue module doesn't discriminate, you can find it in a '76/80 Pinto/Bobcat w/a 2.3L 4 banger, or a 1977/78 Continental Mark V 460, or a gazillion other I-4/I-6/V6/V8 1976/89 applications.
Old 12-03-2016, 07:09 PM
reamer's Avatar
reamer
reamer is offline
Thanks Bill.
I have a new mission, Got to have something to hunt, Ignition modules!
GA_Forester
10-02-2014 08:55 PM
cgi2099
12-13-2011 01:49 PM
torque head
02-26-2011 10:52 PM
il/saltydog63
1978 - 1996 Big Bronco
01-04-2005 11:13 PM
Quick Reply: Will a Duraspark "blue grommet" from a 302 work on a 351?
