Pretty new heads.
I built more or less the same heads . What engine ? what compression ? roller ? cam very important . I am running a 351 w stroker (408 ) 202 heads and a 512 lift roller cam and have no issues on clearance but 9.5 compression . No reason not to do roller rockers stock ratio ( 1.6 ) . If your guide plates are adjustable then you need to look up the proper procedure to center the pushrods . Is your block decked ? You can't go wrong by checking clearance but with 194's and no domed pistons you should be good .
Hi guys no I don't work with a dead line ,it all depends on health and time. But you can bet your sweet bippy that it will be up as soon as possible, I want to try that lo end torque that should be perfect with my 9" posi and my driving habbits. I still run stock steering and suspension so I have no use for a motor that needs to wind up to 9 or 10 to get horspower. Id kill someone for sure. No this is a cruiser that will see an occasional red light every now and then, when the conditions are safe.
Ok for all you guys wondering how I pay for all this its called credit' Its bad news I know believe me I know but with the wifes habbits I figured I may as well get what I need,b4 everything is maxd out yes need ,other wise Id have a blown bb with custom frame built to handle it., a 5 speed manual trans and so fourth and so on. but I love my little driver. It isn't like any body else's but then it wouldn't be me, cause Im definetly an odd duck.
Calm down?, are you kidding .The valve covers you spoke of have got me all tingly inside. Ill have to drop a letter to Santa about those or find a 12 step program to cure this motor thing Im going thru. Oh, some more goodies came in today here are the pics. OH goody
Well after pulling the first head I see this motor has been rebuilt more than once according to the 60 stamped on the piston top. I'm glad its nice and tight and has no wear ridge, because from what I have read 60 over is the max according to some folks and over the max according to others. Any way Ill clean em up and proceed as I don't have much choice in the matter besides it will probably out last me anyway. I do have one question though, does anybody recognize and or know anything about the pistons in this motor brand wise(stock, higher compression lower compression). Any information I can learn about this motor I would appreciate very much. Take care work safe, and above all "ROCK ON"
on
Definitely not a high compression domed piston , I would guess 9to1 or somewhere in that range with your 194 valves and under 500 lift you should have lots of clearance although checking is never a bad thing . You may want to check your deck height and figure out your compression using your head cc's + deckspace + gasket thickness . If you have large cc heads it may drop your compression .
breezesboy
06-23-2017 12:55 PM
Myfreeford
02-06-2011 10:42 PM
psig8
11-25-2006 12:44 AM
pud
01-07-2004 12:58 AM
