'97 150 4.2 injector wire connection to injectors
Old 11-29-2016, 11:50 AM
bl2009's Avatar
bl2009
bl2009 is offline
Is there any way to test/check wire connection to correct injector? I've swapped engines LIKE FOR LIKE ie same engine but haven't a clue as to witch connector goes to whitch injector. I'm hoping there is somekind ot tester or method to identify the connector to the injector? bl2009 Thankyou
Old 11-29-2016, 07:49 PM
bill06447's Avatar
bill06447
bill06447 is offline
They pretty much only fit on the correct injectors...try it
Old 11-30-2016, 12:12 AM
Torky2's Avatar
Torky2
Torky2 is offline
Harness wire color code versus injector number.
The wiring harness to each injector position has a red wire for 12 volts coming through the PCM Power Relay. The color code is for the 2nd wire, that is pulsed to ground by the PCM to fire that specific injector.
Injector # - Wire color code
1 - T
2 - W
3 - BR/Y
4 - BR/LB
5 - T/BK
6 - W/LB
You can use that as a check.
Old 11-30-2016, 09:12 AM
bl2009's Avatar
bl2009
bl2009 is offline
Thankyou ever so much. The color code is just what I was needing. I'll see what happens this weekend. Changing the engine has been nearly a six month project, with lots of interuptions. Maybe I'll be able to lite it up sooon. bl2009
Old 11-30-2016, 09:32 AM
Torky2's Avatar
Torky2
Torky2 is offline
Great! We'll be ready to catch any pistons falling from the sky over here
Hope it goes well!
Old 11-30-2016, 08:33 PM
bill06447's Avatar
bill06447
Did you use another 97 engine or a later block?
Old 12-07-2016, 11:05 PM
bl2009's Avatar
bl2009
bl2009 is offline
Yes, it was a U-Pull-it engine out of same year and model of truck. I tried to start it tonite and am not getting any spark using a Lysle spark checker. and it won't run using starter fluid also. Easy Diagnosis says to use a HEI tester would there be a difference? I did have the front cover off and didn't check to see if the cam position sensor was lined up on 54 degrees, the Haynes book really didn't cover that very well. What's the proper way the see if I'm getting the correct spark or not? Oh yeah, I've got two different style coil blocks. I've tried them both with no fire. Both take the same power connector but the sockets where the wires go look different on the bottom. One is kind of cup shaped the other is more square bottomed. Should I be concerned about the wires that have the hold downs style going into them ? bl2009
Old 12-08-2016, 06:13 PM
bill06447's Avatar
bill06447
First off use your original coil-it's known good. Second, as for the cam synchronizer, you must be at #1 TDC when installing it using the supplied tool. The 54 degree measurement is only to locate the electrical connector-it won't matter where it's pointed if the center is locked to the housing during install at TDC.
Old 12-09-2016, 11:03 PM
bl2009's Avatar
bl2009
bl2009 is offline
A Update:
When pull the cap off the cam positioner the little pointer thing was broken off and was stuck the base magnet. So I'm assuming it was bad. Swapped with the other CPS cap. And in the process of baring the engine around to the #1TC I found the crankshaft sensor wire was off and then found the dangling left over connecting ends ( I had no clue where those wire connectors went and the crankshaft sensor was Sooo buried under the engine that I never seen the connection. It and the knock sensor got hooked up and when I went to check for spark again the engine started (I wasn't expecting that to happen). Anyway after some assembly of the EGR vavle/tube and heater lines and top radiator hoses (just getting the hose clamps pointed so I could get a small socket or screwdriver on them was a real pain). Every thing is under or hide by another component. But FINALLY, I got to take the truck to town briefly. It's got a coolant leak somewhere around the thermostat neck to intake manifold connection. I'll deal with that tomorrow. I did the bar the engine to 26 deg. after TDC method, and the aligned the "C" edges with the middle of the slot and then used a volt meter hooked to the middle wire in the connector and moved the CPS until it just hit the 12 Volts and then tighten the clamp bolt down. It works if you can't find the "Alignment Tool". Sorry for being so long winded but wanted to explain how I finally got the engine to run. Thanks for responding and trying to help. bl2009
cobra1379
04-03-2017 03:47 PM
BD75
6.7L Power Stroke Diesel
18
08-11-2014 03:55 PM
99f250craig
1997-2006 Expedition & Navigator
08-04-2011 10:24 PM
cajunspice
09-17-2010 06:43 PM
ZooDad
32
01-01-2010 07:34 AM
Quick Reply: '97 150 4.2 injector wire connection to injectors
