Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
New truck in the shop 73 swb f600.. and the vin decode says?
Old 04-12-2014, 10:08 PM
Notmeofficer's Avatar
Notmeofficer
Notmeofficer is offline
I traded a small car trailer for "Lil Bit" ...I just love f600 dentsides.. and Kalifornia trucks that arent all rusted out is a bonus.. I feel spoiled when I see some of what the rest of the country has to deal with. The inner fenders are coated with asphalt I imagine from years on road work jobs... a natural rust preventative it is proving very tough to remove
This truck was purchased new by Peterson Caterpillar in California as a fleet service truck. It had a well used service body on it with a massive crane and bumper that would could move a mobile home if necessary. It was (correctly) shortened to a 72 in C/A . The frame was fishplated ending in triangles for several feet beyond the splice.. I couldnt find any cracks or stress... Im pleased whomever did it knew what they were doing. The frame is perfectly square. It had a 9 foot service body which I scrapped for 200 dollars, It had an air compressor in the front of the bed and crane on the rear. Both leaked so much fluid over the years the frame came out totally rust free from being coated with oil. I went at it for an hour with the steam cleaner and it will take two more to get the frame free of all the oil soaked road dirt.
It has the venerable dog 330 ci, 5 speed/2 speed
It had the passenger step modified with steel tubing to hold huge batteries for jumping bulldozers and equipment. The drivers side had a large step tank.. as well as the factory cab tank
I drove it home 60 miles after putting a new carb on it... it had sat for years. It didnt get over 45.. I didnt want to in an unknown rig that had sat for years... I have spent a couple of weeks just cleaning it up, removing the old micro lock and a thousand feet of battery cables and wiring for all the add ons.It was orginally white but has been painted several times over the years with blue and gold stripes and then finally fleet red...
Its used but doesnt appear to have ever been damaged.. just your typical fleet truck
I changed every fluid and put some seafoam in the crankcase for the next oil change. Fluids are measured in gallons,,, gotta love big trucks.I found some field fixes but nothing broken or earth shattering. The ash tray was unused but one of the drivers used the dashpad as his cigarette holder and ruined it.. 250.00 cha-ching
It has a drivers bostrom seat and a little bitty passenger seat.. hence the nickname "lil bit". I think Im going to just clean it up for a ranch truck,,, lightly resto it and fix stuff over time. I intend to build a nice shorty flatbed for it and build a killer IIC bumper.. and Ill probably integrate a rear winch.. why not.. they are so cheap now from hf. (I have several and use them with great success)
Its begging for a navstar or cummins motor.. but Im not sure.. maybe Ill keep it stockish and rebuild the boat anchor 330 at some point. Ive never done a conversion on one but this would be a perfect candidate
The bias ply 20 inch tires are flat spotted from sitting for so long..and whumped whump all the way home when I got it up to speed. I came home on backroads so as to miss Mr Chippie.. just in case I got a commerical officer... and because I had no plates.. just a one day move permit. Mountain driving down some small country roads was interesting.. I was always looking for where I could jump out. Im half tempted to put some super singles on it and make it a super medium duty pickup. Check out the period down exhaust deflector!
I love suggestions...
Vin Number
(Whats in it Bill?)
F60DVT00014
<iframe src="http://s127.photobucket.com/user/notmeofficer/embed/slideshow/" height="360" width="480"></iframe>
Old 04-13-2014, 11:29 AM
rustyrelic's Avatar
rustyrelic
rustyrelic is offline
That was a good read, thanks for sharing.
Old 04-15-2014, 09:14 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
New truck in the shop "1974" swb F600 .. and the VIN decode says?
Originally Posted by Notmeofficer
F60DVT00014
F60 = F600 2WD
D = 330 2V Heavy Duty FT engine.
V = Kentucky Truck Assembly Plant.
T00014 = 1974 / 1974 serial number range: S60,001-U80,000.
Old 04-15-2014, 10:04 AM
Notmeofficer
F60 = F600 2WD
Thank you Bill
Interesting they ordered the hd engine
Old 06-18-2014, 12:05 PM
Notmeofficer
Well... lots has gone on since the original posting
All I can say is to those of you that have done restorations... you understand.. it seems never ending...
I completely disassembled the truck and sandblasted it and chemically stripped it. Three layers of paint came off.. inernational red enamal, peterson cat blue.. with gold stripes, polyurethane, and original white urethane.. and wow was that stuff tough.. even sand struggled to get it off.. theres some remaining paint on the interior roof that didnt want to come of so I roughed it up and will paint over it. I spent at least three hours blowing out sand from all the hidden crevices... I would have dipped the body but alas its Kalifornia and we arent allowed such dangerous things here... I even spent two hours scraping out old seam sealer... new 3m to replace it after a thorough priming... the ford factory welders were fast and it shows in some of the crappy sheetmetal welds,, but hey its lasted 40 plus years so far,, who am I to complain.
The frame was in great shape with original black still in many areas.. the service body was thrashed and while I tried fixing it I gave up after about 20 hours of welding on it. There was gobs of tar from road jobs (probably servicing equipment) under the front fenders, mostly the drivers side ..the good thing is that this kept them absoultely rust free... undercoating to the max.. I think I chipped off 50 pounds
I found some rust in the cab so its getting floor patches and lower pillar fixes.. Im cutting it completely out. There were some dings in the fenders and grill which minor body work will address. The battery area which is usually a rust spot on these trucks was surprisingly unmolested.. I did find some weird holes cut in some areas.. so Ill be doing alot of welding.. I think they drilled in excess of 25 holes in the floor for various devices.. so all of those Ill weld up
The doors have some rust on them.. I have a new aftermarket set that Im going to try first.. if I cant get happy with them ill blast and fix the original doors
The 330 seems in good shape.. so for now Im leaving it alone.. pertronix.. a new radiator and water pump (which was really difficult to source).. wires,, a new holly carb.. weird anomoly I found in the 330hd motor.. it has two side by side thermostats... I wonder why?.. The radiator shroud was in great shape but the over and under air deflactors (rubber and sheetmetal were gone) .. but I was able to replicate them with new sheetmetal and rubber..maybe even better than the originals.. the cross member under the radiator had standing water and gunk in it its whole life.. blasting fixed most of that.. a careful priming and paint job with appropriate rubberized coating will stop any progression of future pitting... and having a radiator that doesnt leak will help too.. The radiator was sourced from several different places but finally NAPA gave me the best price ..337.00... the radiator is huge,,,
When I get it on the road Ill dual exhaust it. The 22.5 wheels are on order.. on the slow boat from europe
Im going to take it off commercial reg and put it in historic.. let dmv argue with me.. I want insurance at 75 a year
I cut out several hndred more feet of extra wiring, more battery cables, accessory switches , dingle ***** etc. All used to start heavy caterpillar equipment or run bed equipment, The dual tank was badly dented so I pulled it. I have the original bostrom seat but I think Im going to put a stock bench back in it as I like them best. There were old matchbooks and receipts from the 70s under the dashpad (which was gone and Ill have to get a repro)
My idea is to put aluminum belly boxes all along under the cab to the back wheels and build a custom flatbed for it. I have an 12 hp air compressor and lincoln ranger welder just begging to be put on it.
Slow progress.. parts sourcing is "fun".. usually starts with a "no" then transitions to a "well.. maybe".. usually I have to do all the research to get the part.. making parts guys look has their eyes glaze over immediately.. F600s arent in the normal suystems anymore.. but F500s still come up for many things.. this truck was built in the days before computers buddy...
Lastly in tribute to its caterpillar heritage i picked Caterpillar yellow at Tractor Supply on sale as the main body color and flat black for the fenders... they have a brand new truck at the cat dealer in this color scheme and I fell in love with it immediately..I cant wait to go back one day and put them side to side.
Theres something about f600 fenders that make them just plain appealing to me.. it shape is like art...
Lastly.. a thanks to all of you on this site for parts.. sources.. suggestions and encouragment... if you like dentsides theres something about these trucks that others just cannot replicate. Ill have about 6-8k in this when Im done..inclding new 22.5s... try a late model medium duty at 5ok... this thing will be a shorty stumpuller.. and perfect for around the ranchito
Im impatient for paint.. but theres lots to do before that...
Old 10-08-2016, 03:04 PM
Notmeofficer
Can you believe two years has gone by
Everything has been done.. every part came off.. everything has been rebuilt
the 330 went away and its a 390/391 forged crank now..everything new.. with an aluminum performer manifold.. the 390 heads fit after machining the oil pump area.. heads got the full commercial dity treatment with stainless valves.. I kept the compression low... 8.5 to one
Dual batteries,, power beyond at the rear bumper for jump starts
Rear mounted 12k pound winch
LED lighting everywhere.. fore.. aft.. winch.. underneath.. work lights backup lights..
Aluminum bed over steel frame
Ranger ten welder
Toolboxes top and bottom.. top steel, bottom industrial plastic (no rust..ever)
Enough tools to run a mobile shop anywhere
New interior
New wiring
New brakes, clutch, steering gear
Old school headache rack exhaust system coming out of a custom bent system with stainless steel flowmasters
New glass, new weather stripping
New radiator
Custom steering wheel
New heater
Every rubber piece replaced
Cat yellow and black
Found the correct ford medium duty tow hooks for the front and custom made some for the rear.. the dock bumper is strong enough to pull a mobile home down
New 22.5 wheels sitting on the bed... still waiting to buy rubber, mount the hood, make the maiden start
Slow progress to being done.. once in a lifetime forever truck..until I get too old to drive it
Old 11-24-2016, 12:01 PM
Notmeofficer
Starting to build the push bumper... like my tow truck but on steroids...
3/8" plate for mounting surfaces
2 x 5" .120 wall tubing for main structure
This one will use 2" round 120 wall tubing as outriggers to protect headlights and grill... just eagerly awaiting my 2 inch die for my bender
The rubber used will be dock bumpers 13" x 12" by 2" ...hard durometer
Needs one more cross piece.. the wings and some light tabs,, the tops and bottoms are already closed up now
Welds... oh yea...
Old 11-28-2016, 05:18 PM
Spirit of '76's Avatar
Spirit of '76
Spirit of '76 is offline
Truck looks great Notmeofficer, more pictures please.
Old 11-28-2016, 09:25 PM
Lucius Parr Designs's Avatar
Lucius Parr Designs
Lucius Parr Designs is offline
Man! You have tons of projects! How do you decide what to work on and when?
Old 11-28-2016, 09:36 PM
Notmeofficer
I write out a long work order list and try to do one minor thing on every truck at least once a week...
Right now I'm spending a lot of effort on my new build..the f600 Mickey wagon beavertail car carrier old school build
I took several years off... Then came back and started garnering parts trucks and build trucks... This year I decided to get off my butt
I'll get more pictures of the " li'l bit" truck build over time...and show the stages...labor of love
Old 11-28-2016, 11:18 PM
Lucius Parr Designs
Where's that build thread? Is that the Supercab I've been seeing?
Old 11-29-2016, 03:23 AM
Notmeofficer
Yes
I have one last f600 sitting in the back of the shop... My 4x4... The frame is done...the axles are done. I am going to do a supercab conversion on it as well using the mickeywagon build as a test bed. It's been sitting for years...I don't mind waiting for the right supercab to come along
I keep a Craigslist ad running for junk dentsides...won't smog dead trucks... From that I get cheap dents that I part out and keep what I like... I'd like to think it's self supporting but I sell parts too cheaply...I'd rather see them go to use and it keeps the flow of trucks moving through. There was one member on here who showed up with a hotshot and took several back to the east coast where a bed is worth six times what they sell for here in California
Old 11-29-2016, 01:10 PM
Lucius Parr Designs
Im down in LA. I've been doing the same thing with 67-72 F500+. Keep what I like and get the rest in to good hands.
47duallyFL
1947 and Older Ford Trucks
06-25-2017 09:46 AM
ABHPage
11-25-2010 12:46 PM
roljr
1999 to 2016 Super Duty
08-03-2010 08:29 PM
wmjoe1953
09-10-2009 09:01 AM
5.4L to Freedom
25
03-25-2009 03:23 PM
Quick Reply: New truck in the shop 73 swb f600.. and the vin decode says?
