2007/2008 mirror swap wire color help
I have an 2007 F-350 SRW. I bought some mirrors of craigslist from two different sellers. They are from 2008 or later, they didn't know the exact year. I have looked in the tech folder and searched and searched. could not find wires that are the same color as mine. Yes,mirrors are OEM. I need to know what color goes to what color. If someone knows please help me out (or my girlfriend as I am colorblind,lol)
Do they match color to color
? question mark represents color that doesnt line up
drivers side door colors=============== new drivers side mirror colors
green------------------------------------------------- green
black--------------------------------------------------black
green/white-------------------------------------------black/white?
blue----------------------------------------------------blue
yellow--------------------------------------------------yellow
red------------------------------------------------------red
brown---------------------------------------------------brown
passenger door colors=================new passenger mirror colors
green/purple------------------------------------------white?
black---------------------------------------------------black
white/blue---------------------------------------------black/white?
green---------------------------------------------------green
brown/purple-------------------------------------------purple?
Side note these are in no particular order as far as pin location.
thanks,in advance
thanks,in advance
Last edited by kingeightclub; 11-28-2016 at 08:18 PM. Reason: i put space between but it did not space when posted
If you go to the website www.bbbind.com/ You will need to register for a free account, once you get that set up then go to the link technical information, hover over that and you will see the option for TSB's & Wiring Diagrams. click on that and then put in your vehicle information and then you should be able to go and look up the wiring diagrams and go from there and get what you are looking for
You should be able to look up the wiring colors for the 2008 and the 2007 and compare what each color is for and then be able to decipher what coresponds to what your looking to do for your wiring connection to make it work for the mirrors.
Hope that helps
Hope that helps
I got it done today. Pretty easy once I figured the colors out.
Driver side door wire color-------------New driver mirror
R/L movement.... red---------------------red
Mirror motor.... yellow-----------------yellow
U/D movement.... blue-------------------blue
Turn signal.... green/white----------green
Ground.... black------------------black
Heater.... green/purple----------black/white
Parking light.... brown-----------------brown
Passenger side door wire color----------New passenger mirror
R/L movement.... green------------------green
Mirror motor.... yellow------------------yellow
U/D movement.... purple------------------purple
Turn signal.... white/blue-------------white
Ground.... black-------------------black
Heater.... green/purple-----------black/white
Parking light.... brown-------------------brown
raytasch
02-14-2014 07:56 PM
rotun
1999 to 2016 Super Duty
03-01-2008 10:19 PM
