1997 F800 GCWR - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1997 F800 GCWR
Old 11-28-2016, 04:56 PM
Frantz's Avatar
Frantz Frantz is offline
Frantz is a name known to allFrantz is a name known to allFrantz is a name known to allFrantz is a name known to allFrantz is a name known to allFrantz is a name known to all
1997 F800 GCWR
I have a customer who currently has his truck registered just for the vehicle. He needs to switch to a combination registration. Location here in Pennsylvania. I don't have any old documents for him. Best I can really offer is to set him up with a truck company to re-certify it, but I don't even have figures to tell him what it should have been new. Anyone know what the max GCWR of such a beast was?
Old 11-28-2016, 10:47 PM
Lucius Parr Designs's Avatar
Lucius Parr Designs Lucius Parr Designs is offline
Lucius Parr Designs is starting off with a positive reputation.
I would decode the VIN and find out what the rear axle could take then depending on that figure out what type of trailer mount it has. Then figure out what the max tongue rating would be for that rear axle/hitch mount set up would be and add the trailer GVWR to the GVWR of the F800.
NOT SAYING THIS IS CORRECT JUST WHAT I WOULD DO TO GET A BALL PARK FOR PAPERWORK. THIS WOULD STILL NEED TO BE VERIFIED BY SOMEBODY WHO KNOWS WHAT THEY ARE DOING.
EX. F800 rear axle rating = 13,000 lbs and GVWR 21,000 lbs
Trailer(combination unit) = Max tongue weight of >13,000 lbs and GVWR 21,000 lbs
GCWR=42,000 lbs
I would also suggest that the trailer has its own set of brakes! (its a must)
Thats how I would do it for registration purposes then figure it out before hauling. Hope this helps.
Old 11-28-2016, 11:27 PM
NoFrod's Avatar
NoFrod NoFrod is offline
NoFrod is starting off with a positive reputation.
My 1990 F-800 has a GVW of 33k, a rear axle at 22k, and a 16k hitch. I suppose that would put it at 49k GCWR. The frame rail truck itself weighs in around 11k.
Old 11-28-2016, 11:55 PM
Quote:
If your trailer hitch is rated at 16k then your trailer GVWR should be 16K. So add all the GVWR's from each unit in the combination to get GCWR.
Your F-800=33K
Trailer(Unit)=16K
GCWR =49K
I would say you are correct
Old 11-29-2016, 08:30 AM
Frantz's Avatar
Thanks thus far! I often have to do new sales registered in combo, but this one is new to me because it's a used truck he found and needs to change the setup.
GCWR Determination texastech_diesel 1999 to 2016 Super Duty 31 08-15-2016 11:26 PM
Auto tranny gear ratios, and rear gear ratio? 1997 F250HD Zodi 1999 to 2016 Super Duty 7 09-10-2007 02:20 PM
77 F250 towing capacity hedgeapple Fifth Wheel & Gooseneck RV Towing 8 12-28-2003 10:31 PM
How do I find my GCWR?? N_fini_T Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 4 02-11-2003 08:48 PM
GCWR and F-150 towing limits will Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 4 03-25-2001 09:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
