1999 F350 CC V10, RWD, DRW - gear change 4.56 or 4.88
All
I have a 99 F350 CC Dually V-10 w/ 4.30's in it right now. Over the winter I want to change the gear set, It is only RWD and I only use it to pull my Bumper tow 30ft Jayco Jayflight (9000lbs) I already have a 5 Star tune and will be doing banks headers this winter as well. Other than tune truck is completely stock. Taking a long camping trip come April and am looking for a little extra power. I would like to be able to use the OD more instead of dropping into 3 just as soon as you start up a hill. Only seeing 8 - 8.2 mpg anyways so what are your thoughts.
Thanks
Angelo
Thanks
Angelo
I'm not sure what size your tires are but my Excursion was running 32" Continentals when I regeared from 3.73 to 4.88s. At that time we were towing a 9,500lb toyhauler and with the stock gears it was seeing 6 to 7 MPG running up/down the East coast on I-95. With that setup it would downshift out of OD if we ran over a shadow.
With the change to the deep 4.88 gears and all other speeds and conditions the same we saw 9 MPG on the same route with the same trailer. And it didn't downshift on the highway a single time between Philly and Savannah.
With those gears and 32" tires it was spinning 2430 RPMs at 65 MPH in OD. And my unloaded mileage dropped from 14-ish to 12-ish with the new gears.
I think buying a Master Rebuild Kit which includes new bearings and crush sleeve along with the new gears is a wise choice. Having a shop that has a good reputation and that does lots of these diff rebuilds is the best bet too, it can be done by the DIY owner but there is some opportunities to miss the correct setup.
Lucky you, your RWD truck will be half the cost of doing a 4X4!
The speedo is driven by the tone ring on the ring gear, so it actually reading tire/axle shaft revolutions per mile. So a gear change will not affect the speedo, my speedo was reading the same with my 4.88s as it did with the 3.73s. A tire size change will affect the speedo because the taller or shorter than stock tire will be covering more or less ground per revolution than the stock sized tire. My factory 265/75R16 tires were 31.6" tall and now with my 35.28" tall Nittos my speedometer/odometer reads about 12% low.
I have the Thorley's sitting in a box. Look like nice stuff. I ordered them through 5star tuning back in July. Couldn't take the truck down during summer to install and to cold now. However specify when ordering if you have a EGR on the drivers exhaust manifold otherwise you'll be trying to figure out how to bypass.
Fortunately 5star is willing to write a tune for emissions purposes, I will have to figure out a way to delete the EGR mess though.
Thanks
Angelo
on
That tire size is shorter than what is usually on these trucks. They are usually equipped with 235/85/16 or 265/75/16, which are very close in diameter. The 215 is smaller diameter so the tire is spinning more revolutions per mile and making you "think" you are traveling farther than you are. So any mpg calculations are going to be skewed because of the different tire size.
The speedometer will also be off by about 3 mph too fast @ 60 mph. So if you are keeping up with other traffic that IS traveling at the correct speed limit, your truck will be turning more RPMs than stock due to the change in effective final drive ratio which will also reduce fuel economy.
Your truck should have a vehicle certification label on the driver side door jamb that will have the original tire size on it.
