Manifold questions?
Manifold questions?
I'm in the middle of a stock rebuild for my '70 F100 and I have a couple of intake manifolds to choose from. This is going to be a daily driver that may see temps. as low as 10°F, if the roads are not too salty. I will be using a stock exhaust manifold.
With or without the spacer?
Since its a '70 I'd use the manifold on the left, without EGR supply hole. But use a spacer - either the correct one for that year or the other spacer from the other intake. Carb hookup will go easier with the spacer.
Also note that you may have two different bolt mounting patterns for the carb - 2 11/16 and 2 15/16. The spacer is slotted to accommodate either spacing, but your carb may not be slotted, so a little rat tail file work mat be needed on it.
whisler
02-21-2012 10:46 PM
LARIAT 85
07-26-2011 11:14 AM
