brake light switch
Old 11-27-2016, 06:19 PM
schoo's Avatar
schoo
schoo is offline
brake light switch
working on my electrical on the f1 and I'm in need of a brake light switch want it to be elect, the harness I'm using has the circuit is in the dash harness so don't want to change it. I'm using a CPP dash mount peddle do you guys have any pic to share of the switch and bracket you used
Old 11-27-2016, 10:18 PM
burnettd01's Avatar
burnettd01
burnettd01 is online now
Brake light switch
Roy
There are a few ways that you can hook up a brake lamp switch under your dash. The Jaguar that donated many parts to my build had a lever type switch that went against the pedal and when the pedal was depressed the lever turned on the stop lights.
I believe mid to late model Fords used a push button switch that laid against the pedal and when the pedal was depressed it turned on the lights. You could use a switch from most any passenger car or truck and make your own bracket.
There is a hydraulic switch that uses brake fluid pressure to turn on the brake lights. I am going to use two pressure switches. One to turn on the brake lights and the other to act as a safety switch. The safety switch will connect to the starter button so I will have to have my foot on the brake to start the truck. I will also have a neutral safely switch to require the engine to be started in park or neutral. It's overkill, but that's how I am going to do it.
The pressure switch would go outside the firewall so that might not work for you.
Here are a couple of photos. Hope this helps
Take care
Dan
Old 11-28-2016, 08:00 AM
schoo's Avatar
schoo
schoo is offline
Thanks Dan I saw the lever type in my searching, the hydraulic would be easier if not for the having the wire there already it's in that pic. Thinking of the push button type
E 250 van switch
Just looking for ideas on a bracket for a lever type or button type and if needed a bump stop and return spring
Old 11-29-2016, 04:03 PM
CBeav's Avatar
CBeav
CBeav is offline
These are pretty easy to mount and the arm can be bent to accommodate a lot of positions. Most labels list them, originally for '52 Cadillacs. Don't pay more than ~$15 for one - a lot of online rod shops, etc. will try to hammer you for $35 and up. $6.99 @ Speedway Motors
Old 11-29-2016, 05:31 PM
schoo's Avatar
schoo
schoo is offline
thanks Beav do you think I need a return spring/bump stop to maybe stabilize the peddle to switch CPP says I should not need one and I could add later
Old 11-29-2016, 08:23 PM
chad77's Avatar
chad77
chad77 is offline
I have to tweak it a bit but otherwise works great.
jeffrey2
02-02-2021 08:01 AM
Shane Carruth
05-07-2016 06:19 AM
jmb924x4
Bronco II
03-29-2010 06:23 PM
laynrubber
11-27-2009 07:10 PM
boogity24
01-18-2004 09:06 PM
Quick Reply: brake light switch
