Duraspark differences
Let me get this straight...you used a DSII stator (AKA pick up coil) in the conversion? A conversion from the DSI?
The DSII came out in mid(?) '76 and used the blue grommet on the ICM. Ford continued this setup well into the 80s.
So I think you're all set if I'm understanding you correctly.
You mean the ICM.....and it had the blue grommet?
The stator and pick up coil are the same thing....what am I missing?
I think the '75s still had points.....Ok, is the wiring harness from the truck to ICM to distributor hacked to hell or still usable?
Ahhhhh.....back to your original question...the stock '76 box (ICM with blue grommet) will work with the DSII.
Wow...you've got quite the compilation of ignition parts! No wonder I'm confused..
The stator and pickup are 84
The truck is a 75 somebody put points in
All with a 74 and earlier distributor
I've always had 74s and 76s so if it was points originally I don't know the wiring isn't there but a box I assume is bad is in there they painted it for some reason
By stator I thought that was the spur looking thing and the pickup the other part in there
It is the blue grommet box by the way
That "spur" looking thing is the reluctor. 8 teeth, spins around making the stator (pickup coil) either "on" or "off".....basically spark, no spark.
The blue grommeted ICM is from '76 on up.
I think there's some wiring to be done...link courtesy of ultraranger
http://www.americanautowire.com/shop...jigaAnXa8P8HAQ
DuraSpark electronic ignition introduced in 1974, but not all vehicles came with it until 1976.
D4PZ-12A112-A .. Stator aka magnetic pickup coil (Motorcraft DU-1A) / Available from Ford & auto parts stores.
ALL 1974/79 FoMoCo V8's except 1979 LTD/Grand Marquis 351W with EEC (Electronic Engine Control aka onboard computer).
Caveman77
01-01-2012 02:48 PM
Justins68ford
11-22-2011 11:06 AM
Blue and White
11-06-2011 02:17 PM
