changing DPF myself
changing DPF myself
Hi guys, have posted before about problems with dpf as reduced engine power and other trouble codes.
Then i ordered the new (guess remanufactured) DPF and after seeing some videos on youtube decided to change it myself.
I did it in about 4 hours without lifting truck. It was not easy, but possible
The main pain was getting dpf out from pipe tube fitting, it was very rusted but a lot of WD40, time, hummer, and it got out finally.
Installing the new dpf was a lot easier. The one problem more was i wasn't able to unsrew oxygen sensor out of dpf's end, but i did not care about it because my new dpf was already with the new one.
And yes, as it was said in instruction which was enclosed with dpf, first thing i did was disconnecting my batteries. After changing dpf i reconnected batteries, started engine, and cleared all dtcs, and everything is ok!!! Now i drive my truck like i'm 16 lucky with boost and speed
If somebody has questions about it, feel free to ask, i will try to help!
Rich, Latvia, Europe
great to hear.
I have a almost new DPF and CAT waiting to go in and ran into rusty . took off all nuts and bolts but the pipes are fused. I have been spraying with penetrate and tourching...no luck. may have to cut off the old and weld in some new pipes to take the new.
was also thinking of doing a 1 into 2 and putting a y pipe after the manifold.
right now Im working on a complete rocker replacement so it will be a while before I finish the exhaust work.
Speakerfritz, i was almost ready to refuse to do it when i saw that pipe from exaust has pieces of metal which stand out of pipe. So i decided to insert some metal piece to underneath that pieces and work with my hummer so i unfolded them and then again penetrate and hummer work on old dpf hanger and it went out. I will post pictures freehand draw sorry that i didnt photos of my work, but when im working 4 hours laying on the ground without help i wasnt happy to take video or photo of my work(
Liquid10Rider
02-26-2011 02:43 PM
