Disc Brakes Conversion
F100/150's have 5 lug wheels on a 5.50" bolt circle, 1973/79's have single piston caliper disc brakes.
F250's have 8 lug wheels on a 6.50" bolt circle, 1973/79's have either single or dual piston caliper disc brakes as it depends on the GVWR
You would not be able to take the '76 F250 front spindles and attach them to your F100 I-beams but, if you swapped the entire F250 front suspension over, it would bolt in. However, you would have to run 8-lug wheels and then you'd have to change the rear end to an 8-lug Dana to match the lug pattern in the front --a lot of work.
If you're going to swap to front discs using Dentside donor parts, you would be better off installing the front discs/suspension from a '73-'79 F100 or from a '75-'79 F150.
If unable to find a donor truck, or locate a salvage yard where customers can pick their parts and save on labor, cost wise, a kit possibly a better option, kits usually include all the components for the upgrade. Anyhow, food for thought?
In upgrading my 65 I spent a great deal of time touring salvage yards, after laboring in removing I Beams, spindles, etc., took the I Beam in to have new bushings installed and found they were not salvageable. Returned and purchased the entire front I Beams, spindles from wrecking yard, did not include the MS, pads, proportion valve, etc.. Later researched and found there was not that much difference in what it cost me to that of a kit.
Posting link as example only; in event decide to go this route, there are a number of manufacturers, perhaps member familiar with the kits will chime in?
http://www.mpbrakes.com/index.php?ro...h&filter_name=
1965 Ford F100 Front Disc Brake Conversion Kit - Legend Series
chucks65
02-07-2018 08:51 AM
chucks65
02-06-2018 01:01 PM
Kalve
07-19-2011 04:32 AM
chuckee
03-06-2001 11:46 PM
