How do I determine rear gear ratio for appropriate speedo gear?
I've read, you jack up the truck put a piece of tape or chalk mark on the drive shaft at the rear universal joint, a piece on the rear wheel and rotate the the wheel 1 full turn and count the rotations of the tail shaft, for instance 1 turn of the rear wheel = 3 turns of the the drives shaft = 3:00 rear etc. well, I did that and 1 turn of the wheel = only about 1 3/4 turns of the drives shaft, now I don't think I have a 1:75 or even a 2:00 rear gear don't think they put anything that high in a a 9" ford, FYI, any ideas if I'm doing this right?
Don
Don
4x4fordtrkn
08-16-2005 05:06 PM
Njbmx
08-13-2002 01:45 PM
