pinpointing vibration help
I believe this is the thread I was thinking of, don't know if it applies in your situation.
https://www.ford-trucks.com/forums/3...tml#post209834
My 99 4X2 4.0L SC, auto is a one piece aluminum drive shaft, so I don't know squat about the two piece set up but maybe a member with the 2 piece set up will chime in. I remember reading in the above thread about the OP saying he had replaced his carrier bearing but don't know if this applies to your set up.
Well boys and girls I made some progress finally !
No question the cross-member bushing are shot but wanted to make sure that was the cause of the vibration so I took some wood shims and put them between the frame and cross-member to take the slop out of the bushings and it worked the vibration is 90% gone as the cross-member can still move side to side.
https://drive.google.com/file/d/0B1v...ew?usp=sharing
Hopefully to close this thread out , I finished the cross member last week has to source new bolts ( order new bolts if you'r doing this ) took her out or a quick spin and no shake on take off but didn't get up to highway speed due to finding out the lower intake gasket failed again and is leaking coolant that's this weekends project .
Hope this helps some one out.
thanks for all the help!
Well I spoke too soon, took her out Christmas morning after replacing the gaskets and she still shakes .
Tonight while fixing a leaky coolant hose I noticed the passenger side motor mount is sitting closer to the frame then the driver side.
Guess ill be starting that this weekend.
Is there a write up on doing the motor mounts?
#30
Ok so I ordered new motor mounts had them overnight delivery.
after looking at the old one and new ones couldn't find anything wrong , the passenger side has less rubber then the driver side.
put a jack under the engine and the mounts didn't separate from the frame.
the bolts that hold the motor mount to the block were backed out tightened them up and she rides smooth as glass at 60 mph .
fairlaniac
1983 - 2012 Ranger & B-Series
04-01-2008 06:43 AM
hellbilly1932
12-10-2007 12:11 PM
