Only getting 6mpg
Old 11-25-2016, 12:19 PM
Knucks's Avatar
Knucks
Knucks is offline
Only getting 6mpg
Hi everyone,
looking to get some input...Can anyone tell me why my fuel mileage is down into the 6mpg? Thats what its saying on my dash, although im sure its fairly accurate because Im not getting anywhere near as far as before on a tank of fuel. Truck is serviced regularly. Thank you
Old 11-25-2016, 12:35 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
What the coolant temp getting too?
Old 11-25-2016, 12:39 PM
Knucks's Avatar
Knucks
Knucks is offline
Not sure the exact temperature, but its going up on the gauge like it normally does. I installed a coolant filter kit a couple months back. The low mpg was happening before I installed it.
Old 11-25-2016, 01:30 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is online now
How does it idle on a cold start? Any smoke out the tailpipe anytime?
Old 11-25-2016, 01:31 PM
Knucks's Avatar
Knucks
Knucks is offline
When its cold out, its been blowing white smoke until it warms up.
Old 11-25-2016, 01:42 PM
Rusty Axlerod
I shoulda asked if you have any electronic diagnostic tools to work with. we need to see some numbers. There are a lot of possibilities but I suspect injector issues. FICM (Fuel Injection Control Module) voltages is where I'd start.
Old 11-25-2016, 02:01 PM
Knucks's Avatar
Knucks
Knucks is offline
I tested the ficm with just the key on, it read 48 volts.
Old 11-25-2016, 02:52 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Live data is what is needed.
One quick way to get that is this tool
https://www.scangauge.com/products/scangauge-ii/
Then program in the Xguages for the Ford 6.0L PSD
https://www.scangauge.com/x-gauge-co...ncoln-mercury/
Here is a how to program Youtube.
Sean
6.0L Tech Folder
Old 11-25-2016, 05:07 PM
87crewdually's Avatar
87crewdually
87crewdually is offline
Is the oil level going up? Or coolant level?
Old 11-25-2016, 09:43 PM
daddykitty's Avatar
daddykitty
daddykitty is offline
how long do you idle?
Old 11-25-2016, 10:09 PM
navistarnut's Avatar
navistarnut
navistarnut is offline
Ouch..........the Cat powered semi I drive at part time gig does that good
Old 11-26-2016, 12:53 PM
r2millers's Avatar
r2millers
r2millers is offline
Originally Posted by Knucks
Hi everyone,
First I'd manually check your mileage to be sure the gauge is correct.
Next, you really need some engine data as suggested.
Is your turbo spooling up? Any loss of power? Rough at startup? Last time you changed your fuel filters?
We need to see info with koeo and engine running? What's your Baro, ebp psi, MAP, etc. EGR?
Lots to evaluate on these engines.
Obviously speed and towing have some affect but 6 mpg is ridiculous.
Old 11-26-2016, 03:42 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Verify that the parking brake is off.
Could have a bad bulb.
Sean
6.0L Tech Folder
Old 11-26-2016, 07:30 PM
Blakshukvw's Avatar
Blakshukvw
Blakshukvw is offline
Possible dragging brakes.
Otto396
15
11-04-2015 06:56 PM
ballbandit
24
04-23-2014 10:22 AM
Jimmy Dean
12-16-2013 03:43 PM
78fordman
10-20-2013 11:49 PM
Milwaukee1979F150
01-30-2011 12:36 PM
Quick Reply: Only getting 6mpg
