Front Axle Dust Excluder Seal?
I understand that the B-series Mazda is a Ford Ranger with different name badges for the most part so I post this here to see if any of you guys can help out. Am about to tear into my '02 B4000 4x4 front suspension to replace those seals that I understand are officially called excluder seals. It's those seals that the CV axle goes thru in the knuckle/spindle. Mine started making a crunching type noise and I can make it stop temporarily by sticking a screwdriver in from the back and move the seal but it comes back eventually so am gonna rip into it and replace both sides. My service manual, if I'm interpreting it correctly, makes it appear they are called knuckle oil seals and calls for a couple of special tools (205-399 and 205-400) to install them. Does anybody know if these are the same seals I'm describing above? Here are some pix of the area where the seal goes from both sides, passenger and driver's. One side has the seal ripped out and the other side is still in there. Its right in that gap where the CV axle is going thru the knuckle/spindle into the hub assembly. Also a pic of the 2 different seals that are "supposed" to be for the truck. The shredded one is the one that got ripped out and the other larger one is what I bought that appears to fit into the hole in the knuckle. At least that's what the Mazda on-line parts store lists. I bought the smaller ones and they appear to be the one that got ripped out. What's really weird is that it doesn't appear there is one of the larger one is in there unless you have to pull it apart and would see if from the outboard side. I may be wrong because I haven't torn it apart yet.
When I inspected and lubed my CV half-shafts I replaced the excluder seals. Wasn't a big deal, I used a block of wood and rubber mallet to tap the new seals into place working my way around. Make sure they're fully seated so they don't spin on the outer CV cup.
you'll need to make sure the inside of the knuckle where the seal contacts is cleaned up. I had to wire-brush and sandpaper to get everything shiny. Then pack plenty of grease in.
The number I used for my 2002 was YL2Z-3K070-AA, might be different for your Mazda though.
CrowneVic
01-15-2013 10:41 PM
