JBL Antenna cable
JBL Antenna cable
So I installed a new radio in my '95 exploder limited with the JBL system. Was looking for the antenna wire and found it with a coupling right after it comes through the firewall. It has a real odd connector and not enough length to make it to the stereo. 2 electrical wires go through the wirewall with it, maybe for a power antenna. I unhooked it from the box in the back and there was the same oddball connector. Also that box has a sticker on it that says cellphone only and I have an antenna in the back quarter glass. Man I should have just found as XLT. lol I've looked for adapters but not sure what that end is. Anyone have any experience with this that would know an easy solution besides replacing the whole antenna.
Did your '95 have the original radio, and if so, how was the antenna connected to it? It seems unlikely that the original radio would have had an antenna pigtail longer than than adapter. I'm curious why this would be too short.
Since you have the JBL system, it seems you maybe should have purchased this bypass kit which has the antenna adapter along with the amplifier bypass. I'm not sure if this antenna adapter is any longer though.
-Rod
-Rod
HRTKD
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-05-2017 08:15 AM
drtry10
09-01-2008 08:48 PM
78Ranger_GARedNeck
06-06-2008 11:39 AM
