351m so confused please help
Hey everybody, getting confused on this 351m in a 79 f150 4x4 i bought for 500$ ive rebuilt the carb, changed valve gaskets, and changed fluids
the previous owner changed alt, distributer and cap, tuned up etc. for some reason it idles fine (little pinging from driver side rear @valve cover) but soon as i put it in gear itll spit and stutter, itll drive down the road at no more than a light half throttle in 4lo loc, struggles in 4hi loc (np203) but will half throttle spin tires in dirt (converted to manual hubs for 2wd) and none of the vacuum lines make sense, most have been capped off or lead to nowhere.
I'm confused about your run-on sentence.
Are you asking about the "pinging" coming from the left rear valve cover? Pinging usually denotes an ignition/timing problem.
Are you questioning why she "spits and sputters" when put in gear? As in a carb problem?
Do you have a C6 trans? Is there a question about the trans only getting to half throttle in 4WD?
I don't think you have an NP 203, rather an NP 205 unless someone did a "downgrade." Nothing wrong with a 203, it's just that in '79 the 205 was king. And you shouldn't be driving in 4 wheel, Hi or Lo, with the hubs locked, at more than 15 mph or on dry, hard surfaces, for an extended period of time, let alone throwing up dirt.
What are manual hubs for 2WD?
Is your question one concerning vacuum line routing?
yes i am guessing a carb issue,as it struggles under load going down the road.
i do have np203 with
4hi loc
4hi (does not stay in gear)
n
4lo
4lo loc
i was told i should not have factory manual hubs, so im assuming the previous owner installed them to take the power away from the front wheels? i leave the front hubs locked out rather than in.
im very confused with the most of the main vacuum lines, many are missing, others just run out to nothing under the frame, the previous owner used it on a farm and jerry rigged it over the years.
On the M Block, set the timing to 12* BTDC. Pull and plug the distributor's vacuum advance line first. I don't know if you're running manifold or ported so pull and plug it. Then, check the vacuum advance can to see if it's in good shape...apply suction to the line leading into the can. If there's resistance to vacuum (or sucking hard), it should be ok. If you feel no resistance it's time for a new one.
Take her for a spin after you set the timing, under various load conditions. If you still hear pinging, we'll play with timing/vacuum advance next.
4hi loc
n
4lo
4lo loc
4hi loc
n
4lo
4lo loc
This is from a 79 Bronco, loaded, 400, C6, 4WD
Vacuum lines are the same for the 351M/400.
Webbf250
41
06-19-2018 04:41 PM
brokersteve
09-16-2012 01:03 AM
yield2s
12-28-2006 10:49 AM
adamsre
05-06-2005 07:48 PM
