power windows
Window Wiring diagram
The attached wiring diagram in conjunction with a volt ohm meter should help you sort it out - since NOTHING is working. If the REAR window isn't working either, you may have a bad Accessory relay or ONE critical wire connection somewhere not making contact - like under the accessory relay.
mrjimbov
Electrical Systems/Wiring
11-23-2014 07:20 AM
ramorius
13
06-22-2005 04:41 PM
