Which transmission?
What does it say on the gear indicator? PRNODD1, or PRND21?
RUG SR-OD Single Rail 4 Speed Overdrive M/T: 1978/83 F100/150 300/302
RTS TS-OD Top Shift 4 Speed Overdrive M/T: 1984/89 F150/250 2WD/4WD & Bronco 300/302/351W
on
This is/was popular manual transmission speak and it can get confusing because there was just about every possible combination available in 3, 4, and 5 speed gear boxes over the years, smart people first indicate the number of forward gears the trans has and then specify if OD is present.
How many times does the trans shift up when accelerating? If it is 3 times then you likely have the E4OD 4spd automatic with the top gear being on overdrive ratio, if it only shifts twice then you have the 3spd C6 trans which does not have an OD ratio. The AOD 4sp auto was also available in the late '80s to early 90s but it wasn't factory installed behind the 5.8. That doesn't mean you don't have one because it will bolt in there are work just fine with the correct flexplate, but it would have been swapped in at some point by a previous owner.
Anybody want to chime in with a 3 speed overdrive automatic
Received 3,102 Likes
on
dealership salesmen freaked out when i ordered the 91 and 92 trucks with the C-6 trans. "why get that when the E4OD is a much better trans"
6 trucks, all with the same engine and same trans means only one part is needed in stock, not one part per truck and try to figure out where the part needed for that truck was at 2 am to get the truck back running.
dlmoore
06-13-2006 02:07 PM
Professorjinx
05-21-2004 01:30 AM
elsmith
07-15-2001 10:59 PM
